Patch how-to: manifold air temperature logging
Old Feb 27, 2009, 07:25 AM
  #286
MR Turco's Avatar
Originally Posted by SkyNight
Ok, we wait the V6 with SD
it should already support SD. Just need to copy over the tables and definitions.
Old Mar 14, 2009, 07:05 AM
  #287
bnice01's Avatar
you can find the sensor w/pigtail at summit. Fast shipping and seems a bit cheaper.
sensor (I know its a msd part number but its the same sensor)
http://store.summitracing.com/partde...0&autoview=sku
pigtails
I ordered this wed night and it got here friday morning, they have a supplier in GA.
Old May 13, 2009, 09:49 PM
  #288
raasfaas's Avatar
pigtails
Bringing this thread back from the dead, apparently bmotorsports no longer carries the gm iat sensor...I just need to confirm that this sensor works the same as the gm...I'm just about hitting the order button, thanks.
Old May 13, 2009, 11:32 PM
  #289
RoadSpike's Avatar
found a combo save you 5 bucks
http://www.rs-autosport.net/catalog/...roducts_id=216
Old May 14, 2009, 04:51 AM
  #290
raasfaas's Avatar
Originally Posted by RoadSpike
Cool, thanks man
Old May 14, 2009, 11:44 AM
  #291
evo8dad's Avatar
I would imagine this - Ballenger Motorsports new GM IAT sensor - would work as well. Just doesn't include the pigtail.
Old May 15, 2009, 03:27 AM
  #292
NINJA63's Avatar
pigtail is here!
http://www.bmotorsports.com/shop/pro...roducts_id/855
Old May 15, 2009, 05:54 AM
  #293
raasfaas's Avatar
I went with the combo from rs-autosports...it worked out a little cheaper
Old Jul 6, 2009, 07:43 PM
  #294
raasfaas's Avatar
Sorry to have to bring this thread back from the dead...I've been going through the threads and really haven't found anything conclusive...I had posted this in the water/alcohol section but got no response...
here's the question I posted:
"for those running the stock uicp with stock bov configuration, when you switched to SD, have you encountered any problems placing the iat sensor between your meth nozzle and the bov? I ask this because I'm about to get my sensor installed but the space to work with is very limited...my meth nozzle is about 1/2" right before the rubber elbow that goes to the tb but the space between the nozzle and the bov is no more than 3-1/2"...do you think this is enough space for the iat sensor. I'm in the process of switching over the SD, what would be the effect if I placed the sensor a little further downstream like behind the bov?
Old Jul 6, 2009, 08:05 PM
  #295
l2r99gst's Avatar
You'll be fine if you placed the sensor before the BOV. The temps aren't going to be any different in different places on the UICP. As long as you're post IC, you'll be fine.
Old Jul 6, 2009, 09:03 PM
  #296
raasfaas's Avatar
thanks for the reply...I just wanted to make sure that it wouldn't affect my switch over to SD in any way since most of the threads I've read people were always referring to putting the sensor after bov/before meth
Thanks
Old Jul 7, 2009, 12:02 AM
  #297
Asmodeus6's Avatar
It should be fine. But FYI, I've been spraying methanol directly onto the AIT for over a year now. The AIT came first... nearly 2 years ago with the Maft Pro / SD conversion. It went directly before the TB. Which means the meth had to go in between that and the bov...
:shrugs:
Hasn't been a problem yet. And it's within 3" and on the same side of the UICP. So it gets absolutely blasted by the meth. 882ml/min... every day.
So if you are having placement concerns... remember its a $12 sensor that you can get at any auto parts store if it sh*ts out.
Which I have already done because I had the UICP let go of the TB at 30psi and bust the sensor clean off when the pipe struck the brake booster...
It will be fine wherever you put it post IC.
Old Jul 7, 2009, 04:38 AM
  #298
leecavturbo's Avatar
bummer
Old Jul 7, 2009, 05:51 AM
  #299
raasfaas's Avatar
ok thanks man...
Old Jul 7, 2009, 05:52 AM
  #300
cij911's Avatar
Mr. Fred / et al -- Great post and lessons learned so far! The only questions I have are, what have you learned about the turbo, how are the various FMIC performing, and what are the benefits of switching to IAT and SD (hp ?)?
Evodad8 -- Did you ever post your tests of FMICs ?
Quick Reply: Patch how-to: manifold air temperature logging
