Patch how-to: manifold air temperature logging
#316
Manifold air temp is still needed as it will vary depending on engine operating conditions (WOT vs cruise, etc).
i may need and IAT for my car....88580014
#318
#319
IAT is not needed for SD, but MAT is needed. Lucky for you, JDM Evo 9's already have a MAT sensor in the IM. You should be able to apply jcsbanks JDM Evo 9 SD ROM, and be ready to go with no changes to the hardware other than to uplug your MAF sensor and put it on a shelf.
#320
Any pictures or how tos for a nice intake heat shield ? I have mocked some cardboard templates, but would like to see what others are running...
I am using a Perrin filter on an Injen intake....Thanks in advance
#321
what do i need its a JdM IX with 88580014 (AUDM rom). i switched roms for added support and ease of finding tables.
what tables do i need? from what read, there is an easy speed density setup for the IX turbo?
Thanks again for your time.
#322
Look at my thread on SD patches. There is one for a JDM Evo 9. It has no tephra mod's support at this time though. Word has it that tephra may be releasing a tephra ROM for the JDM Evo 9 in the near future though.
#323
i will post a pic when i put it in my Map tomorrow and i can work from there.
i am guessing i will need to do some bits to remove the MAF CELs, etc.
thanks again for your help.
#324
one last question, please excuse my noobiness lol...
since i am on 88580014 (AUDM) will be able to utilise the MAT? i know i do have a JDM so there is a MAT but will it be "enabled" due to the rom switch?
thanks i am almost done modding my rom/tables to include the SD tables.
#325
#326
Yes, it will be enabled when you switch to a JDM ROM.
i just dl'ed his rom it has a lot of stuff in there, a lot of which is real high level. i made a reply on there hoping to get some feedabck i want a simple JDM rom with the following:
Tephra's Mods
direct boost control
SD
MUT table
Periphery bits
i dont need DMA, Live mapping, Asynch (whats this???) and ALS
it looks like i may have to get a bone stock rom and work it from there
BTW mrfred have u ever done direct boost control for the JDM rom?
#330
