Detailed mapping of Periphery bits underway
Old Mar 23, 2009, 08:30 PM
  #31
Darwinn's Avatar
Originally Posted by GST Motorsports
The EDM 6spd has a trans temp sensor? really? That is very interesting.
Yes we have it.
I have mine temp sensor installed back, because without sensor car goes into 0% wgdc and maybe something more. Next time I'll put resistor.
Old Mar 23, 2009, 11:28 PM
  #32
al\lupo's Avatar
Do you know if there is a MUT code for trans temp?
Old Mar 24, 2009, 07:16 AM
  #33
mrfred's Avatar
Someone needs to look at the ECU wiring diagram in the EDM Evo 9 factory service manual. If someone can report back the pin number, I can report back the ADC input and associated RAM addresses to log.
Since EDM Evos also lack manifold air temp measurement, my guess is that the ADC input 0E is used for tranny temp on EDM cars. This is the same ADC input that is used for fuel temp on USDM cars.
Old Mar 24, 2009, 03:17 PM
  #34
ExViTermini's Avatar
Originally Posted by ExViTermini
So I guess if we disable bit 4 of FCA then the p0300 will plague us no more?
EFDF to EFCF bit 4 is the only diff.
bump to the next page
Old Mar 24, 2009, 03:31 PM
  #35
kkarim's Avatar
Originally Posted by Darwinn
Yes we have it.
a 10k resistor instead of the sensor will solve your problems
didn't feel like waiting for a rom patch. :P
Old Mar 24, 2009, 03:33 PM
  #36
mrfred's Avatar
Hmm.... Did you see this thread:
https://www.evolutionm.net/forums/ec...0300-test.html
Old Mar 24, 2009, 04:47 PM
  #37
Wow, I'm an idiot. I saw that thread in the search and thought it was the same as the other similar one. Sorry, the search changes are still messing with me.
Thanks so much Mr. Fred!!!
Old Mar 24, 2009, 10:05 PM
  #38
mrfred's Avatar
Yes we have it.
Started a new thread on the topic:
https://www.evolutionm.net/forums/ec...m-evo-ixs.html
Old Mar 24, 2009, 10:17 PM
  #39
Appauldd's Avatar
Any chance of getting an updated detailed periphery map?????
Old Mar 24, 2009, 10:25 PM
  #40
mrfred's Avatar
Sometime in the next month or so, I hope to take all the recent finds and get them into an updated set of xmls for the next release of ECUFlash. Probably close to a month away though as I'll be spending my near term time doing some maintenance and adding some new components to my Evo.
Old Mar 24, 2009, 10:29 PM
  #41
Appauldd's Avatar
No problem.....I am more than willing to wait.
You amaze me with your capabilities. Thank you.
Old Mar 25, 2009, 04:08 PM
  #42
03whitegsr's Avatar
Could you include FEA bit.10 and bit.9 as it is active on the EVO VIII where bit.8 and bit.7 are not active.
Old Mar 27, 2009, 06:15 AM
  #43
raasfaas's Avatar
Can the periphery tables be added to V1.29a? I have the tactrix 1.3 cable but it doesn't seem to work with any other version of ecuflash thank 1.29. I was told that there is a software update that I need to do but I've been emailing tactrix for about a week now with no response.
I know the tables were added to v1.35 and higher, but is it backwards compatible?
Old Mar 27, 2009, 07:56 AM
  #44
mrfred's Avatar
The original Periphery tables work with v1.29, but the newer Periphery Bit tables do not work. If you bought the cable from Tactrix, I suggest calling Tactrix. Make sure you have a copy of the sales receipt in-hand, or else you'll get no assistance with updating your cable because without one, they'll assume that you have a pirated cable. Contact Limitless if you bought the cable from them.
Old Mar 27, 2009, 08:50 AM
  #45
raasfaas's Avatar
I got the cable from tactrix but it was so long ago I don't even know where to begin to look for that receipt...I'm going to give them a call anyway and try my luck. In the event that they choose not to help me, mrfred could you point me to the older periphery tables...I've searched and only came up with the new ones. Right now I pretty much need them to disable my lean spool (the better way), disable my EGR for the JDM Map patch, etc.
Thanks for the help.
Worst case is I'll just have to go buy one of the 2.0 cables which I really dont want to have to do.
Quick Reply: Detailed mapping of Periphery bits underway
