Detailed mapping of Periphery bits underway
Old Apr 16, 2009, 02:00 PM
  #61
todd6027's Avatar
Isnt FBA bit 0 for leanspool not bit 7 , in periphery1 if you change 0009 leanspool on to 0008 leanspool off it changes bit0 from 1 to 0
Old Apr 16, 2009, 02:06 PM
  #62
gear head's Avatar
Yes, that's correct
Old Apr 16, 2009, 02:09 PM
  #63
todd6027's Avatar
FAA
bit 14 front o2 sensor heater circuit
bit 4 for full time open loop set to 0
bit 1 rear o2
FBA
bit 0 lean spool
Old Apr 16, 2009, 04:46 PM
  #64
tephra's Avatar
0xfba bit0 is leanspool - not bit7
0xfaa bit2 is immob disable - not bit5
also 0xfaa bit10 is "timing knockdown on light acceleration < 3000rpm"
not sure if the others are right on not...
Old Apr 16, 2009, 04:47 PM
  #65
tephra's Avatar
crap - didn't see the followups
Old Apr 16, 2009, 08:14 PM
  #66
Deepnine's Avatar
http://evoecu.logic.net/wiki/Periphery_Configuration
i updated the wiki, can you all check, if its all right?
Old Apr 16, 2009, 10:52 PM
  #67
03whitegsr's Avatar
FCA bit 4 and 5 are for the P0300 check, right?
Old Apr 17, 2009, 11:11 AM
  #68
todd6027's Avatar
Old Apr 17, 2009, 11:14 AM
  #69
cossie1's Avatar
Bit7 was listed in what I put together, due to the earlier mod that barryC put together.
Disabling bit 7 seems to mess with the comms (can't get fault codes from the ecu etc).
Old Apr 17, 2009, 09:25 PM
  #70
ace33joe's Avatar
FCA bit 1 is listed as P0421 here, is the FCA bit 1 the only one related to this P0421 test? If so, I guess I can just turn this off to disable P0421 test without affecting other rear O2 related test?
I have a 200 cpsi metal cat, and I usually do not get this code, but I had this one when I was cruising on highway on a cool day.
Old Apr 17, 2009, 11:27 PM
  #71
merlin.oz's Avatar
ace33joe, unfortunately, FCA bit 1 did not fix the P0421 on my 88580013 rom.
Maybe it will on yours though.
Old Apr 18, 2009, 06:26 AM
  #72
ace33joe's Avatar
Thanks for your input. So does AUDM EVO IX have a rear O2 sensor as USDM EVOs? I checked JDM Ralliart EVO VIII rom and those two bits related to rear O2 sensors were indeed off. I guess I will try it off and see if the light ever comes back. (Although I had the P0420 SES light only once so far and didn't come back yet)
Old Apr 18, 2009, 12:30 PM
  #73
merlin.oz's Avatar
Yes, the AUDM9 has then rear sensor.
Aside from the tephra fix, the only other known fix is the sensor extender or positioning the sensor after the main cat.
I had a go at adding a 4k7 ohm resistor across the rear sensor, which did change/reduce the signal voltage. Have not had time to verify if this is an actual fix, though it looked about right on an oscilloscope.
Old Apr 18, 2009, 12:42 PM
  #74
logic's Avatar
merlin: mrfred and acamus were working on a patch to disable the heater check as well (actually, acamus had some working code for a relatively generic enable/disable scheme).
Although...thinking about this a bit more, wouldn't it be even simpler to disable the tests you don't care about entirely via the periphery, then use jcsbanks' DMA work to set any tests to a ready state, if OBD-II testing is a concern in your area?
Old Apr 26, 2009, 08:14 AM
  #75
fixem2's Avatar
What does FAA Bit 0 do? SOmewhere in the last month I switched it from 0 to 1 in my ROM and want to know what it does and if it is contributing to some issues I am having? ROM = 96530006 Tephra 5.10.
Quick Reply: Detailed mapping of Periphery bits underway
