2byte load log issue
My ecu flash crashed 2 weeks ago, i reintalled it and now my 2byte load in evoscan reads a 4 digit number and it wont map trace or graph anything no matter what is checked. My main concern is to fix the 2byte load problem cause i can still see logs on excel.....thanks much
What do i have to do to ...
you were probably reflashed your car with the original based data (without the 2-bye load modification) since you reinstalled EcuFlash. So EvoScan is reading garbage now.
ok... now i reinstalled the ecuflash1.30 and its logging the correct loads on the excel spread sheet but it wont show the map trace.....??...thanks for your help.
