V5, NLTS and the load threshold bug
Old Jun 17, 2008 | 08:47 PM
  #31
dudical26's Avatar
bump for update.
Old Jun 17, 2008 | 09:39 PM
  #32
tephra's Avatar
https://www.evolutionm.net/forums/sh....php?p=5786831
check the second page for 88590015 5.8 test link...
Old Jun 17, 2008 | 10:48 PM
  #33
dudical26's Avatar
I was referring more to the issue of getting the NLTS to work with the bottom clutch switch.
Sorry for the confusion.
Old Jun 17, 2008 | 11:03 PM
  #34
tephra's Avatar
oh right...
well i havn't tried
if you can work out if the bottom switch is connected to the ecu then we can try and find the memory variable for it
Old Jun 18, 2008 | 08:37 AM
  #35
mrfred's Avatar
Unfortunately, its not connected to the ECU.
Old Jun 18, 2008 | 08:49 AM
  #36
l2r99gst's Avatar
Trying to use the bottom switch for NLTS would just be like flat shifting without any NLTS control. You may never even contact the bottom switch during the shift, and even if you did, it would be for a split second, after the RPMs already have raised due to the clutch being disengaged. So, you would probably hit the normal rev limiter before any time for a NLTS limiter to kick in.
Old Jun 18, 2008 | 07:04 PM
  #37
dudical26's Avatar
Lucas English has reversed his switch and he said he really likes it. Makes the RPM respond much quicker when coming off the NLTS.
Old Jun 18, 2008 | 07:05 PM
  #38
dudical26's Avatar
Originally Posted by Jack_of_Trades
I'll see if I can find a replacement switch which has a longer throw for anyone concerned with this. I know I accidentally trip the NLTS all the time when starting a WOT run.
any luck
Old Jun 18, 2008 | 07:27 PM
  #39
Jack_of_Trades's Avatar
I haven't had a chance to look into it yet,sorry.
Old Jun 18, 2008 | 07:49 PM
  #40
l2r99gst's Avatar
Maybe Lucas has an aftermarket clutch that engages close to the floor then?
On a stock engagement, where it is towards the top of travel, I don't think using the bottom switch would be much different than not using any NLTS control at all.
I guess it all depends on your particular setup and shifting methods, etc.
Old Jun 18, 2008 | 07:59 PM
  #41
dudical26's Avatar
Yea it definitely depends on setup and user preference
Old Jun 22, 2008 | 09:34 PM
  #42
fostytou's Avatar
EvoM Community Team
In regards to this post:
https://www.evolutionm.net/forums/sh...0&postcount=29
(this is actually where I meant to post that)
Here are your logs:
http://thefrost.net/randomfiles/Open...617_LogSet.zip
Unfortunately I'm an idiot and didn't log gear/speed to make it easy, but there is an image of what all I did log for you. Hope that helps with anything! (even though I know that we have the new idea/working for that patch). There are a bunch of downshifts there... I'm guessing the easiest way to find them would be to look for short bursts of load.
Old Jun 22, 2008 | 09:47 PM
  #43
tephra's Avatar
ok have you tried V5.8 to see if it fixes the LTB?
Old Jun 24, 2008 | 04:08 PM
  #44
fostytou's Avatar
EvoM Community Team
No... I haven't had the time lately with work so I was planning on patching at full release.
Old Jul 8, 2008 | 07:44 AM
  #45
dudical26's Avatar
Hey Jack, I know your a busy man but have you found anything for a clutch switch with longer engagement?
tephra
Aug 5, 2024 08:23 AM
tephra
Aug 19, 2016 11:07 AM
taylorgang
Apr 9, 2014 04:30 AM
scheides
Mar 1, 2014 10:45 AM
BluEVOIX
Aug 28, 2012 03:17 PM
