Load = performance???
could load readings in evoscan be used to compare one car to another?
eg. 2 evo 6's doing a 3rd gear pull on a straight/flat bit of road.
am I correct in thinking that the higher the load the more power you have?
.....its just that my evo 6 pulled higher loads at 19psi in third gear than a friends tme that was running 23psi
usually higher load with minimal knock implies more power but if the MAF/intake air data was messed up (due to bad intake or sensor), it's also result in higher load as well and it'll be wrong for the power calculation.
I helped a friend data logging the car and his loads were abnormal high at high rpm above 6000. I found that he had a "frankerstein" intake (AEM or Injen pipe I'm not sure and HKS filter) that messed up the whole thing. He can't be making over 400 whp as logged by evoscan. :-) LOL.
yeah thats kinda what I was thinking!
does weight play a part? - trying to get my head around it....I'm thinking if you have more weight then you need more power to move it.....ending up with the same result???......does this make sense?
.....going for a lye down now....me head hurts.....lol
cheers
Something like that, which is why you typically don't see the same load in the lower gears as the higher gears. In the higher gears, there is more resistance working against the car, which drives up exhaust gas temp, which of course spins the turbine faster (which tends to increase load).
I was just trying to point out that adding timing definitely effects torque directly. I am not saying that is an option in your case, if you are already running maximum timing for your setup.
This makes perfect sense, seeing that igniting the fuel earlier would give the mixture more time to burn and therefore produce more force on the power stroke. Timing is degrees before top dead center that the spark plug fires. Too early and you explode while the piston is still traveling up, but too late and you don't burn the fuel efficiently and make less power.
Adding boost will also increase torque though.
rt turbo
17
Aug 5, 2004 05:37 AM
