Openport 2.0 - June 15th
Old Jul 29, 2008, 09:48 PM
  #46
Mike01gsr's Avatar
Originally Posted by razorlab
I can imagine they will have some front end to check off what items you want to datalog then it will datalog straight to the SD card without a laptop
Gotcha, I guess I can see it working like that. Guess I will wait and see.
Old Jul 30, 2008, 08:31 AM
  #47
EvoM Community Team
fostytou's Avatar
Pricing released and cable is pre-orderable. Says it won't be stocked until tomorrow and may not be fully supported yet:
$169 for base unit http://www.tactrix.com/product_info....91262166416032
$189 with all adapters. http://www.tactrix.com/product_info....products_id=40
Still wondering if this will be able to loc AYC/ABS/etc Ecu info
edit: also, I didn't think about this before but where do you think it gets power from?
double edit: looks like it will be able to log AYC/ABS ecu!
Able to apply GND or 5V-20V to OBD pins 1,3,9,11,12,13 or AUX 2.5mm stereo connector
Old Jul 30, 2008, 09:23 AM
  #48
dudical26's Avatar
I wonder if coding the front end is done for allowing configuration of logging to the onboard micoSD
Old Jul 30, 2008, 11:04 AM
  #49
RazorLab's Avatar
Received 1,056 Likes on 764 Posts
The pricing has been there for awhile and it's not pre-orderable, you can add to cart but it won't let you buy it.
Check my post a couple posts ago.
Old Jul 31, 2008, 08:05 AM
  #50
EvoM Community Team
fostytou's Avatar
ah junk! oh well ... i just tried to order one and razorlab pwns
and I see now that it looks like the module with the processor and the MicroSD slot plugs into the OBD2 location and the other cable goes where the white connector normally goes. I thought that the connector next to the mini-usb was for the serial innovate serial though, but now it looks like its for the power (white) connector?
Old Sep 19, 2008, 08:26 PM
  #51
Seriph's Avatar
Does the OpenPort 2.0 replace the need for EVOScan? Or do you take the information from the SD card and still use EVOScan?
Old Oct 15, 2008, 05:02 PM
  #52
nothere's Avatar
got word back from tractrix on sd logging, the Innovate answer refers to their (innovates , currently 1.3 openport/logworks) logger.
SD logging should be available fairly soon. I checked with our developer and he said that he's looking to activate that feature within the next two weeks. As innovate is a separate company, I don't know what their ETA is on providing a program -I would check with them directly...
regarding your question^ I think you use evoscan within the sd logger, but I really don't know.
Old Oct 17, 2008, 10:19 AM
  #53
RAbishi's Avatar
That will be nice to be able to log to the SD card.
Old Oct 25, 2008, 07:34 AM
  #54
nothere's Avatar
one sad bit about the new OP2, doesn't look like it will work with innovates logging software.
I asked Innovate support and their answer is "no but we are looking at it".
As busy as Innovate is I don't think we will see anything from them in the near term (as in years). I had hoped development was coming from tactrix, evidently they are swamped too.
This is really a big deal as the innovate logging platform is about as feature packed as you can get in a free handout. Its simply the best out there.
alexc
For Sale - Miscellaneous Automotive
Mar 12, 2017 08:54 PM
youra6
Dec 23, 2016 08:57 PM
smanders
Dec 11, 2016 12:43 PM
Evodetailer123
Oct 3, 2016 07:37 AM
Quick Reply: Openport 2.0 - June 15th
