Evo 10 - Ecuflash - 3 tables
#78
#85
3D
<map name="Initial WG Duty A" type="3" active="1" help="" class="Turbo" map_struct="" level="0">
<rows scaling="Evo32_axis_Rpm16" count="16" offset="#60DB8"/>
<cols count="17" offset="#60E3E" storagetype="uint16" func_2val="[value]" func_val2="[value]" format="%.2f" metric="" caption="" desc=""/>
<data count="1" offset="#5910D" storagetype="uint8" func_2val="[value]" func_val2="[value]" format="%.2f" metric="" caption="" desc="" inc="1" incb="5" incdata="0" incdatab="0" inc_dir="1" order="rc" color_dir="1"/>
</map>
<map name="Initial WG Duty B" type="3" active="1" help="" class="Turbo" map_struct="" level="0">
<data count="1" offset="#59225" storagetype="uint8" func_2val="[value]" func_val2="[value]" format="%.2f" metric="" caption="" desc="" inc="1" incb="5" incdata="0" incdatab="0" inc_dir="1" order="rc" color_dir="1"/>
</map>
<map name="Initial WG Duty C" type="3" active="1" help="" class="Turbo" map_struct="" level="0">
<cols count="17" offset="#60E3E" storagetype="uint16" func_2val="[value]" func_val2="[value]" format="%.2f" metric=" Volt" caption="TPS Voltage" desc="TPS Voltage"/>
<data count="1" offset="#5933D" storagetype="uint8" func_2val="[value]/1" func_val2="[value]*1" format="%.2f" metric=" %" caption="Adjustment" desc="Adjustment" inc="1" incb="5" incdata="0" incdatab="0" inc_dir="1" order="rc" color_dir="1"/>
</map>
</map>
</map>
</map>
#90
yes
<map name="ECU ID" type="1" active="1" help="" class="Ecu ID" map_struct="" level="0">
<data count="8" offset="#5001C" storagetype="uint16" func_2val="[value]" func_val2="[value]" format="%.2f" metric="" caption="" desc="" inc="1" incb="5" incdata="0" incdatab="0" inc_dir="1" cols="1" view="hex" color_dir="1"/>
</map>
<map name="ECU Ver" type="1" active="1" help="" class="Ecu ID" map_struct="" level="0">
<data count="1" offset="#5002C" storagetype="uint16" func_2val="[value]" func_val2="[value]" format="%.2f" metric="" caption="" desc="" inc="1" incb="5" incdata="0" incdatab="0" inc_dir="1" cols="1" view="hex" color_dir="1"/>
</map>
<map name="ECU Label" type="1" active="1" help="" class="ECu ID" map_struct="" level="0">
<data count="6" offset="#3FFFA" storagetype="uint8" func_2val="[value]" func_val2="[value]" format="%.2f" metric="" caption="" desc="" inc="1" incb="5" incdata="0" incdatab="0" inc_dir="1" cols="1" view="char" color_dir="1"/>
</map>
Ecu id is 5236-16
ECU label is SM5236
</map>
</map>
</map>
Ecu id is 5236-16
ECU label is SM5236
