FIC 1050s installed today - observations and a question
#76
mrfred, does playing with the cold start enrichment tables (https://www.evolutionm.net/forums/sh...d.php?t=347668) affect your warm/hot start at all? It appears that other different brand large-injector users experience similar issues.
#77
#87
The density of the two fuels is similar. Its the higher flow requirement for E85 that's different. I'm sure that's what you meant. The injector scaling should take care of the fuel flow difference, so I think that as long as good latency values are selected, the only thing that should need changing is injector scaling.
#88
mrfred, When you installed the injectors did you notice anything about how they seating into the chambers? I am installing now and notice they don't sit as deep into the chambers as the stock injectors. THoughts?
#89
The fit is definitely snug, and the rail has to be fully tightened down before they will appear fully seated. Its definitely necessary to lube the o-ring and also the donut seal at the IM. I found it helpful to jiggle the injectors around as I was cinching down the rail. That helped fully seat the injectors in the IM.
#90
Thanks for the tip. I found one of the injectors not fully seated in the rail while jiggling them. Reseated the injector and everything installed well. Now to the tuning.
Is there a special way to adjust the latency? If you use the + on the cell it maxes out. If I type 980 I get a 975 in the cell and can't get another adjustment until 1008. Is this correct?
