FIC 1050s installed today - observations and a question
#123
I also wonder if you lean it out enough, maybe you can use values that are close to the stock IPW adder values?
#126
I'm using mrfreds settings at 6000' and they have been working very well. What cranking enrichment adders are you guys using for pump and E85? The default values from 96530706 work great for cold starting E85 (13.8ms@45degrees), but the warm start ones were way too high. I dropped the warm start (>180degrees) to 0.2ms and it starts basically like stock.
d
d
#129
d
d
#131
i used ur voltages and my idle is -3% !!! scaled to 1083cc i think the sheet of latencies and sized they give you may play a role. because there very close to what the sheet says. gonna check my cruise trims in a few. also have no warm start issues.. like i did with stock 560s
#132
Hate to revive an old thread, but I just installed my FIC 1050's and I have the same exact issues on warm start. I have tried both mrfred's original scaling/latencies and the revised ones later in the thread. Has anyone come up with a definitive fix?
#135
I solved my warm/hot start with the settings I posted Here=> https://www.evolutionm.net/forums/8034843-post70.html
