JDM 3bar MAP Sensor + Evoscan 2.2
Hi all,
1. I own a JDM Evo8.5 MR and I suppose my car is equipped with the 3 bar MAP sensor.
2. I am currently using Evoscan 2.2 + openport 1.3 USB cable to log my car's data
3. I failed to log the est. boost value from evoscan given that I have already ticked the "JDM MAP" box before starting the log (it stayed at -14.5psi all the time).
4. Do I have to log other features at the same time when I log the "JDM MAP" to record the boost value?
5. Do I need another evoscan version? Do I need to modify something from the evoscan program files? Also, anything to do with my rom file/decription (xml) file?
Too many questions and that's why I divided them into 1 to 5. Help me pls!!!
If I'm not mistaken, you need to change some table values in evoscan to make it work.
Maybe the pro's will chime in..
In the meantime, read this and search around..
https://www.evolutionm.net/forums/sh...ight=log+boost
Sick9, thanks! I am still searching if there was a thread talking about JDM MR as I am using 97250001.xml decription file that is not mentioned in your menioned thread.
mrfred
Feb 26, 2022 06:16 PM
evo4mad
May 5, 2015 06:22 PM
