Meth Fuel Map---is this look correct?
That is your fuel map and timing map with meth injection?
Are you sure the kit is actually spraying? Is your wideband correct?
The fuel and timing looks very very very conservative for meth.
Do you have upgraded injectors? If so, what brand, size and what do you have them scaled to?
You said you are running 28psi peak? That would put your around 0 to -1 timing according to your timing table.
I run more more peak boost timing than that with 27.5psi on straight 91 octane.
Your right on with the peak load coming in around 3500 rpm at 290 load. Sooooo how much timing would this thing take? If it is that retarded then it def way down on its power. which actually makes me happy. I like knowing there is power in it.
Thanks for all the replies.
Code:
TPS LOAD RPM BOOST IDC 100 263 5500 -0.5 64.53 100 263 5625 -0.5 67.20 100 261 5750 -0.1 67.47 100 261 5843 25.5 68.56 100 260 5968 25.5 70.02 100 258 6093 25.3 70.19 100 255 6187 25.3 69.95 100 253 6281 25 71.02 100 250 6406 24.9 72.43 100 248 6500 24.5 73.49 100 244 6562 24.1 72.79 100 241 6656 23.9 72.42 100 237 6750 23.5 72.00 100 235 6843 23.6 72.99 100 235 6937 23.6 72.51 100 231 7031 23.4 72.00 100 230 7125 23.3 72.96 100 227 7187 23 72.06 100 223 7281 22.9 73.00 100 220 7343 22.8 73.63 100 218 7406 22.7 74.26 60 215 7468 22.2 73.29
