Evoscan 2.3 released.
Old Jun 23, 2008, 02:31 PM
  #61
sponners's Avatar
so can the classic impreza wrx (jdm) be logged now with this version?
ie....impreza 1993 onwards.
Old Jun 23, 2008, 09:12 PM
  #62
EvoM Community Team
fostytou's Avatar
Originally Posted by tnt1106
If i understand correctly, since i just bought my cable (1.3u) I can not use any of the new features of the acd logging? (it doesnt have pin 1 or 9 or both?) plus i have that distracting "under 15mph" blink light issue. so I need an older cable to make use of new release features? I'm a bit confused about that part.
side note: does anyone else get random reconnects (where the lady tells you "logging engaged" and missing bits of data in the log stream?) Mine randomly seems to just a few seconds from time to time. of course its when i hope to have that part of the log to review...
thnx
If you just bought a cable it and it makes that light blink it shouldn't be the tactrix cable. Look for the OBDII pinout I posted in another thread and make sure you don't have pins 1 or 9. Information on making things work properly should be in that thread also.
Old Jun 24, 2008, 06:57 AM
  #63
tnt1106's Avatar
Thanks frosty! It seems that I have the later style cable with pin 1, but without pins 3 or 9. So I should be good to go. I am however still puzzled as to why Evoscan (2.1) seems to "reset" at times and when it does i lose about 10 seconds worth of logs. (seems to do it more at lower speeds).
Old Jun 24, 2008, 02:57 PM
  #64
Jack_of_Trades's Avatar
I wanna know why I'm logging these "saw tooth" graphs like Tephra mentioned.
Old Jun 24, 2008, 03:03 PM
  #65
tnt1106's Avatar
Originally Posted by Jack_of_Trades
I wanna know why I'm logging these "saw tooth" graphes like Tephra mentioned.
same for me back to 2.1 i guess heh
Old Jun 26, 2008, 04:40 AM
  #66
SeanV's Avatar
Originally Posted by SeanV
Same problem here. I did pay for Ver 2.1 and I do have a serial number.
Definately not in my junkmail and nor in my deleted items.
I also tried logging a new support ticket, and when it prompts u to
"Please enter the number displayed above:"
it doesn't accept the number, even if you have entered it in correctly.
Where to now?
Thx Hamish for the quick response. I logged a support ticket on the Evoscan helpdesk and was sorted out with the download link.
Now I have a different problem.
I could never get my IDC/fuel trims to log with ver 2.1, even after editing the dtat settings with the info posted here on the forums.
Now that I have ver 2.3 installed, I was expecting my fuel trims and IDC's to work straight away. they don't and I have no idea what the problem could be.
Any ideas what I could check....
Thx
Old Jun 26, 2008, 02:37 PM
  #67
Still no word on the saw tooth logging??
Old Jun 26, 2008, 03:23 PM
  #68
rob82's Avatar
Is there a way to increase the sample rate - have found the subaru logging quite slow. Also is there way to log EVO9 mivec timing?
Old Jun 26, 2008, 04:46 PM
  #69
gsrboi80's Avatar
My logs are all jagged too. Map Tracer does not work it only gives me like 4 points on the whole map. Same in all three logs I did today.
Wierd. Seems like the log timing as mentioned
HELP US
Old Jun 26, 2008, 06:46 PM
  #70
tephra's Avatar
saw-tooth... just waiting to Hamish to release a fix.
Not sure what his plans are about it, maybe create some support tickets to get the ball rolling
Old Jun 26, 2008, 06:52 PM
  #71
chmodlf's Avatar
I do not think evo4mad views evom as much as we think
Last Activity: May 28, 2008 02:54
Old Jun 26, 2008, 07:12 PM
  #72
tephra's Avatar
yeah I probably wouldn't either with everyone complaining :P
Old Jun 26, 2008, 10:48 PM
  #73
Psh, you started it
Old Jun 27, 2008, 06:57 AM
  #74
gsrboi80's Avatar
Does you guys' map tracer work properly or are you seeing the same only couple point being generated to the map
Old Jun 27, 2008, 08:01 AM
  #75
gsrboi80's Avatar
Glad I still have the email from 2.1 going back now. Need to retune and 2.3 isnt gonna work for me right now
Quick Reply: Evoscan 2.3 released.
