Evoscan 2.3 released.
#123
I believe it needs around 16 minutes for each but I'm not certain. I think I recall someone saying the ECU checks the trims every 4 minutes or so and doesn't make the full changes until it sees four blocks of 4 minutes total so you probably don't HAVE to just let your car idle for 16 minutes straight or cruise for more than 16 minutes in one trip. I'm not a pro on the 'trim knowledge' though,lol.
#126
Is having LTFT lo at 3.04 and mid at 2.84 mean that it's really off in Evoscan v2.4? I know in the notes panel it says to have it within 5%, which it is but the idle is really rough and the AEM UEGO reads it full lean and occasionally around 16.x's
These are on PTE 1000cc injectors we installed in a friends car.
Any help would be appreciated
#127
Those are great trims... BUT, it may not have settled yet...
Usually a lean condition like you describe is a leak somewhere... ( I remember a boost leak is rich and an exhaust leak is lean or vice versa)... Or, your scaling/latencies need a little tweaking.
-E
-E
