Evoscan 2.3 released.
Below is the content from the release email that I received describing some of the new features:
EvoScan v2.3 New Features:
- NEW Mitsubishi EFI / ABS / AYC Actuator Testing and Bleeding.
- NEW Hybrid DSM 1994/95/96-99 Eclipse, 3000GT, DSM Datalogging capabilities. (use the EvoScan OpenPort cable or your favourite FTDI OBDII cable)
- NEW 98-2006 SSM-II Subaru Support (use the EvoScan OpenPort cable or your favourite FTDI OBDII cable)
- NEW 89-1998 SSM-I Subaru Support (9pin Cables in stock 1st July)
- NEW US OBDII Diagnostic Trouble Code support
- NEW Evo Diagnostic Trouble Code support and actuators.
- NEW Faster graphing, Gauges and UI response rates.
- NEW Gauge background and transparent images functionality.
- NEW Innovate Wideband Serial Protocol 1 and Protocol 2 logging.
- NEW Zeitronix Wideband Sensor Boost accuracy.
- NEW Map Tracer better xml support.
- NEW Gauges and Gauge Layouts.
- NEW Mitsubishi AYC and ABS requestids, includes GForce, Lateral Gs, Brake Light, Steering Angle Degrees, Steering Angle speed, etc... Note: For Mitsubishis this only works if pin9 is disconnected on Universal cables, disconnecting pin9 on universal cables also stops the EFI diagnostic lights from flashing, and you can tick the "disable flashing lights" under the Logging menu in Evoscan. pin9 is only used for subaru 2002 reflashing and interferes with Mitsubishi diagnostics. Next week I will be selling a specific Mitsubishi cable with no pin9 for those that like to purchase them already to go.
NEW Gauges and Gauge-Layouts Included..
Reminders:
- Car PC Interface - use "Evoscan.exe /AutoStartDatalogger" to automatically begin logging on PC startup.
- EvoScan support helpdesk, you can log any discussions or requests at http://www.evoscan.org/helpdesk
- Disconnect Pin9 on universal cables if you are only using it for Mitsubishi vehicles.
Development In-Progress for Evoscan v2.4:
- Innovate MTS Aux chain inputs.
- Trigger datalogging on Throttle Position Sensor %.
- WebCam - Record up to 8 webcams simultaneously.
- GPS Tracker - with Lap and Sector Split times. Gauge and image overlays.
- Increased Subaru support, and more Evo4/5/6 DTC support.
EvoScan Mitsubishi 1994-2006 Supported Vehicles:
Supports ALL 1994-2006 USA/EUROPEAN/JAPANESE Mitsubishi Vehicles.
Mitsubishi Evo 4/5/6/7/8/9/GTA/FQ, Lancer, Eclipse, FTO, Galant, VR4, Colt, Mirage, Mivec Mirage, L400, L200, 3000GT, Pajero, Shogun, Space Runner, Grandis, Carisma, SpaceStar, SpaceGear, SpaceWagon, Sigma, Diamante, Outlander, Montero, Magna, Expo, Verada, Delica, Dodge Stratus, Eclipse, Eclipse GT/GS.
EvoScan Mitsubishi 1989-1994 Supported Vehicles:
1989-1994 Mitsubishi Eclipse, 3000GT, GTO, Dodge Stealth, Eagle Talon, Plymouth Laser, Galant VR-4, Lancer GTI 16v, Colt, Summit & Mirage (CSM), Evo I, II & III, and other Mitsubishi vehicles fitted with a 12-PIN Mitsubishi diagnostic port.
NEW - Hybrid 95-99 DSM/3000GT/Eclipse (16Pin) Supported Vehicles EvoScan is the first to support these vehicles. Select "Hybrid" and select ECU "EFI" in EvoScan.
EvoScan software is confirmed working with these vehicles, using the EvoScan 1.3U Datalogger/Reprogramming cable.
- Mitsubishi Eclipse/DSM (1995 and 1996 support Hybrid MUT Protocol)
- Mitsubishi 3000GT (Hybrid MUT Protocol)
- Mitsubishi Eclipse (Hybrid MUT Protocol)
NEW - EvoScan Subaru SSM-I 1989-1998 Supported Vehicles:
All 9pin/16pin SSMI 1989-1998 Subarus. (9pin Cables in stock 1st July)
NEW - EvoScan Subaru SSM-II 1998-2006 Supported Vehicles:
All 16pin SSMII 1998-2007 Subarus.
Support in progress:
34) 2000 Australian Holden VTII HSV Clubsport (support in progress) Found that it uses LS1 protocol, also earlier models use ALDL protocol. Found that this is the same as GM vehicles in the U.S.
35) Nissan (support in progress) Found that it uses CONSULT protocol
36) Honda (support in progress) I have a handful of honda test ecus.
37) Australian Ford (support in progress)
38) USA Ford/USA GM (support in progress)
39) 2005/2006/2007/2008 ALL Vehicles... Protocol support for OBDII/CAN/VPW/PWM.
40) Support for Serial Com Port cables. (support in progress)
41) Support for ELM323/ELM327 Cables. (support in progress)
42) Support for Mercury/Mercruiser Speedboats. (support in progress) Found that it uses a 2pin or 4pin plug for most models.
Reminders:
does this mean i can plug in my tactrix cable to a 92 Eagle Talon TSI turbo? that would be awesome to be able to datalog DSMs as well... anyone know where the diagnostic port is? i didnt think they had one...
When he talks about Universal cables and pin 9 does he mean Evoscan or Tactrix cables? I would like to log AYC/ABS/ACD but don't know if I can with a modification to my Tactrix cable?
I didn't get an email of the release.
How do I go about getting an upgrade of my version 2.1 (which I paid for) to version 2.3?
Surely i don't have to buy 2.3 if I already bought and paid for 2.1
Thx.
Thx.
