fuel cut problems
fuel cut problems
k guys i just installed a intake filter and running 50/50 meth. and 27 psi of boost. My problem is when im logging and doing WOT runs in 3rd gear it feels like i hit a brick wall or the car cuts fuel i dont kno if its that or boost cut . i was looking at my looks and at the time i fell the brick wall my IDC is at zero so is this fuel cut. also during my install i messed up the honeycomb in my MAF. so i took the honeycomb out form fear it might chip little chips in to my engine. So what is this feeling of hitting a brick wall ? Can some one help me Thanks
Log your load, then go into Ecuflash and raise your boost cut limit to a number higher than your load. If you are seeing loads over 320, increase the timer. Get another MAF honeycomb, it acts to smooth the air out and make it more laminar as it flows through the MAF.
k sometime i do hit loads over 300, are you talking about boost delay timer? rite now i dont have the money for a new maf. and my load scale is up to 320 if that helps anything
Yes. That is fuel cut and this is the table dude is talking about;
How messed up are the honeycombs? If it's not too bad they can be straightened with the right sized allen/hex wrench.
