Tactrix Boost Control Solenoid (Plug-n-Play for Mitsu)
Did you guys see this?
It was added to the Tactrix site a few days ago. Is this the answer to our plug-n-play BCS dreams?
http://www.tactrix.com/product_info....d0a9bdd71766b1
Tactrix 3-Port Boost Control Solenoid (Mitsu)
[PD3PBCSM] $109.00
This Tactrix 3-Port Boost Control Solenoid uses the same high quality German solenoid previously sold by Prodrive. When tuning with aftermarket engine management, this will allow you to take control, and raise the factory boost level. The Mitsubishi Factory Boost Control Solenoid is not capable of handling high boost pressures, and will become uncontrollable at higher pressure. This is controlled by any aftermarket engine management that allows you to set wastegate duty cycle. Comes with harness for plug and play install with Mitsubishis. Please note that while mechanically and electrically speaking this solenoid is plug-and-play, it absolutely requires map changes in your engine management to operate safely and control your boost levels
[PD3PBCSM] $109.00
It looks like that is the plug and play solution. I already cut and soldered the OEM wires to a resistor in series to the GM 3 Port wire harness.. Then it plugs and play to a GM 3Port Solenoid. The plug and play solution for me now is to keep using the GM 3 Port if in the future it fails. GM 3 Port is cheaper but if you do not want to cut cables that will do it.
2.) This solution would be more stable switching between high boost and low boost maps.
3.) You could still use all the nifty JDM Map sensor and ECU boost control stuff.
It's a prodrive 3 port solenoid. They have been used on subarus for years.
I checked the subaru plug this weekend and it's the same as the Mitsu one except the one raised line is on the opposite side. If you file it down you are good to go.
I wonder if that is what tactrix is doing.
GM solenoid is still much cheaper. I wonder if we can find somewhere to source those plugs.
The Prodrive, Perrin and GM BCS are all reasonable replacements and all are 3 ports. The real benefit is running the BCS in interrupt vs. the stock routing which is in Bleed mode (On both Subaru and Evo's, the stock BC system runs bleed mode)
3 ports in interrupt also let you drop the WGDC across the board to achieve the same boost as you would in Bleed.
A hybrid Manual/electric boost control setup is by far the easiest to tune and offers the full throttle punch of an MBC with partial throttle control boost control. A hybrid MBC/EBCS system only works if the EBCS is 3 port and run in interrupt.
The Perrin EBCS is a remachined version of a 3 port solenoid sold by Grainger for about 30.00.
/Brox
/Brox
/Brox
/Brox
so if I plug and chug this into my vehicle, I can now control boost with EcuFLASH and not hack any wires?? Seems like a deal to me.....anyway to get one of these to log boost? That would be nice.....(trying to minimum the devices i need for tuning..)
