Innovate LM1 "Cuts-out" while logging Evoscan 2.3
First, I am using a Macbook Pro running bootcamp.
Using Evoscan 2.3 Beta and final 2.3 release, logging my afrs will work for a little while then abruptly cut out when letting off the throttle. It seems like any lean condition 70:1 and up, the logging for wideband stops. Rarely will I see the logging for wideband turn back on.
I had addressed this issue with Hamish during the Beta version but it seems like it's still an issue, at least for me. It seemed less sensitive on the beta version.
Does anyone else have this problem or know of a solution?
I made a .net program to read to log and fill in the blanks with the last value. Here it is.
https://www.evolutionm.net/forums/sh...d.php?t=361521
... use the search...
However, I could tell you to search as well. I posted this question a whole month before your Log Fixer post. You could've replied here.
even after restarting, still bugging when going over 100:1.
The only fix i found is not let over 99:1 ....
So get a co-pilot with you when logging, so he can stop de logs
xPRimNT
239
Jun 2, 2016 10:40 PM
