Evoscan
Evoscan
Hello there,
I just got my LC-1 kit and the Evoscan 2.3. Somehow i can get the Evoscan 2.3 to read the ECU (Using Tactrix 1.3 cable) and log the Wideband LC-1 with a USB-Serial converter simultaneously. Do anyone have encounter such problem before?
Just now i try to use evoscan to log wideband LC-1 "only" and it can log, but if i try to read from the ECU using tactrix 1.3 USB cable, then i will have problem logging the Serial converter Comport.
If i leave 2 USB device plug into my PC while dataloging using evoscan, i will have corrupted data read from the ECU.
Please help. Thanks
Please help. Thanks
Yup, thats the problem.. bro... Sorry for my bad english.
If i connect the LC-1(USB -serial converter) and read using evoscan 2.3, it is working fine,
and if i connect the tactrix 1.3 and read with evoscan, it is also working fine. Just that, when i connect the LC-1(USB-serial converter) and tactrix together, the evoscan cannot read the ecu data correctly and somemore will have error message: "COM2 error"
Ok guys, finally i got my problem solve. So going to share it here just incase some of you have the same problem as mine.
1. I plug in the Tactrix 1.3 and start the ECU log by pressing the "start datalog" button. (untick the wideband AFR)
2. Then i plug in the LC-1 serial cable which is connected to the USB-serial converter into the notebook USB port.
3. Once i have plug in the USB-serial converter, then i tick the wideband AFR and it is reading perfectly.
3vo|3oost
Apr 4, 2012 05:39 AM
Danner
Aug 13, 2011 11:13 AM
