Asus Eee issues
Old Jul 11, 2008, 04:59 PM
Eastside's Avatar
Asus Eee issues
I just picked up this http://www.bestbuy.com/site/olspage....=1213046768451 Eee pc at my local best buy and i'm having problems getting evoscan to work.
I'm using 2.4 and the problem is when it goes to waiting for INIT response it will restart trying to connect over and over.
It never says anything about the link being engaged but when you stop it it says link disengaged.
I've only used it with vista not yet with xp so I'm not sure if there's something different I need to do.
Like the x86 drivers are the right ones for xp?
Or, I don't know.
I'm lost.
This little computer sure is cool though, it has a 8.9 inch monitor instead of the 7 just barely fits in the glove still.
Anyone have any ideas?
Old Jul 11, 2008, 05:02 PM
Eastside's Avatar
I'm using a Tactrix cable and it's an IX.
Forgot that bit.
Old Jul 11, 2008, 07:16 PM
asdfasdf128's Avatar
try an older version of evoscan. (1.29 specifically)
Old Jul 11, 2008, 07:25 PM
Eastside's Avatar
Any idea how I can find it?
I've only used it since 2.3 so I don't have anything older than that.
Old Jul 11, 2008, 08:27 PM
RazorLab's Avatar
Received 1,056 Likes on 764 Posts
v.99 works just fine on my eeePC
Here are some evoscan versions:
http://www.norcalmotorsports.org/use...Scan_versions/
Old Jul 11, 2008, 08:28 PM
PM me your email addy. I have it on my computer & cant attach it here.
Old Jul 12, 2008, 01:34 PM
Eastside's Avatar
Did you have to do anything special to get .99 to work?
Or any tricks when installing or setting it up?
Old Jul 12, 2008, 03:45 PM
juyanith's Avatar
For what it's worth, I'm using Evoscan 2.4 on a new vista laptop (not Eee though). Everything seems to work fine.
Old Jul 13, 2008, 12:57 PM
RazorLab's Avatar
Nope, just worked.
Old Jul 13, 2008, 02:47 PM
Eastside's Avatar
Another question I hope someone has an answer for.
When i'm installing the drivers for the Tactrix cable it says they have not passed xp testing or something to that effect and it says it may mess things up.
Is there different drivers I should use or is this ok?
Thanks for the help so far guys.
Old Jul 13, 2008, 03:35 PM
RazorLab's Avatar
Yes that is normal, just hit continue and install.
Old Jul 13, 2008, 05:34 PM
Eastside's Avatar
I'll try again soon and see what happens.
I tried using .99 when I still had 2.4 installed and I got the same problem.
This time it'll be a clean slate with just .99, we'll see what happens.
Old Jul 15, 2008, 03:42 PM
Eastside's Avatar
Okay so I have .99 installed.
I'm using the cable drivers from 2.4 I didn't see any with .99, did i do something wrong here?
Here's what it says when I get it connected and try to log.
Info: Initalizing At 5 baud...
Info: Initalization complete...
Info: Waiting for INIT resopnse...
Info: AutoReconnect Retry #1
And so on.
Anyone have any clue?
I have yet to get this computer to do what I bought it for.
I need help.
Old Jul 15, 2008, 05:29 PM
RazorLab's Avatar
If the cable works fine with your other laptop I think you have a driver issue on the new one.
I would deinstall the drivers, restart, then plug the cable in and let it ask to install the drivers and do so.
Old Jul 15, 2008, 08:29 PM
Eastside's Avatar
Am I alright using the ones from the 2.4 evoscan?
Or is there some others?
I'll try that as soon as I make sure i'm using the right drivers.
I've already mentioned the xp testing warning.
Quick Reply: Asus Eee issues
