IX running rich, changes to fuel table not working
Old Jul 14, 2008 | 10:44 AM
Kierkegaard's Avatar
Exclamation IX running rich, changes to fuel table not working
Wondering if you guys can help us out. I'm getting tuned on the dyno right now, and we can't seem to figure out why the car is running so rich, specifically running in the 9s almost everywhere. We've tried taking fuel out and it doesn't seem to resond. Mods on the car (IX) are full TBE w/TP, intake, fmic, and custom o2 dump. We've never run into this problem before. Any help would be tremendous.
Old Jul 14, 2008 | 10:45 AM
Oh, and it will be difficult to give you logs because the car doesn't even want to rev.
Old Jul 14, 2008 | 10:55 AM
MR Turco's Avatar
have you checked for boost leaks? Does the car run with the stock map? Your mods shouldn't require any changes that would cause major fueling issues.
Old Jul 14, 2008 | 10:57 AM
bigric09's Avatar
is your front O2 connected ? are you throwing a CEL ? is it seated properly ?
Old Jul 14, 2008 | 11:01 AM
It's running rich on the stock map. We'll re-check the front o2. It also has a new Wally 255
Old Jul 14, 2008 | 11:04 AM
MR Turco's Avatar
how much fuel have you tried taking out. i.e. what does the map say for AFR where you are seeing "9s"?
Old Jul 14, 2008 | 11:06 AM
13.3 and 12.4 where it starts
Old Jul 14, 2008 | 11:08 AM
MR Turco's Avatar
Does it start in open loop or closed loop? You said you cant get it to rev so i assume it is everywhere. I would check the O2 sensor like mentioned or you may have a massive boost leak.
Old Jul 14, 2008 | 11:12 AM
starts in open-loop. Front o2 seems to be fine. No codes or anything.
Old Jul 14, 2008 | 11:20 AM
MR Turco's Avatar
o2 wont matter if it is only in open loop.
Old Jul 14, 2008 | 11:24 AM
No boost leak either
MR Turco's Avatar
Whats your fuel pressure at idle?
Looking at the dyno, the a/fs drop as soon as the car gets into boost
Old Jul 14, 2008 | 11:36 AM
MR Turco's Avatar
Things i can think of checking are, fuel trims, accel enrichment, fuel pressure, maf scaling.
Old Jul 14, 2008 | 11:40 AM
all that looks normal
