ecuflash dies again
ecuflash dies again
i have had this problem once before and really cannot remember how to cure it.
now, whatever version i install, its all messed up, however now, i have version 1.34 installed, i can open some roms, but the ones that do open, have weird values accross the axis's
for example
my load line looks like this
2560|5120|7680|10...|12...|
my rpm axis looks like this
128
12
128
16
no matter which version i install, and i have tried removing everything, all the drivers and traces, it now just either opens with a mess such as above, or totally crashes dependin which rom i open.
any help is appreciated
thanks
for example
128
12
128
16
thanks
no i have never done anything, however even old or new versions, i now get the same problems, also with certain roms, the whole system simply crashes when you try to open
The scale thing does look like a th little/big edian thing. I have found that ECUflash "remembers" where you put old xml files and still uses them, I zip my old ones and that cures it, but you might have to do a clean install. Which ROMs are giving the bother?
MB
MB
so when did the chang happen?
how can i work this out?
start again with which version? And is ther a download of all of the xmls i can find?
i do have a working version on 1 pc of 1.32 (i think) so whichever rom files on tihs pc must work fine, which version of the xmls will this be?
i stil think the pc has a problem, but if i follow someones instructions and still get the error then we can go from there
well, if i take my xmls from my pc thats working with 1.34 and then totally uninstall everything on this pc, then i reinstall 1.34 on this pc, copy the xmls over to this pc, then run, i get the same problem, nothing changes.
also, when i open 1 particular rom, the program just closes
so any help possible?
ok thanks to grayw i have fixed it, i reckon it was copying the xmls over not zipped up causing corruptions from the working version, i downloaded the latest ones i could find in zip form and reinstalled wiped the registry and all traces and its working
thanks all
thanks all
