Evoscan v2.4 fixes
I was resonding to my power and torque calculations not working in any version of EvoScan I have seen but the data from Evoscan when imported into Dataloglab is sufficient to create relatively accurate numbers according to others.
Quote:
Originally Posted by oldevodude
It would be nice if ther torque and HP calcualtion work. Is it just me? If I log with old Evoscan .99 and place data in Dataloglab it works. I imagine it's just a formula or something. Anybody getting HP and torque figures accurate?
Evo4Mads' replay;;;;; "I used a formula an evolutionm forum member posted, I may revise it somewhat in the near future."
sorry for the confusion It would simply be nice to get power and torque graphing and calculations/logging working or simply removed if it is not going to work.
I have the same problem too. It is because when you log fewer parameters it logs faster and the LC-1 cannot keep up with the faster rate.
anyone else have problems logging items when ZT-2 is hooked up? I can log ECU parameters perfectly...then i hook up the ZT-2 and wanna log wideband info and boost from the ZT-2 and nothing gets logged at all. Open up a datalog in map tracer and nada.
I got 2.5 from Hamish yesterday but I'm still getting all zero data with 64bit Vista. He might be holding off the release while he works on it some more but that's just my guess. I'm thinking I just need to setup this laptop to dual boot XP.
Any idea if I'm doing something wrong when making formulas in the "edit data items list"? I'm trying to do the calculation:
[InjDutyCycle]*[EVOLC1]*0.0363436
And it won't do it. I had it working in 2.1 but it won't do it now. I've double and triple checked my spelling. I don't know if its a bug or my dumba33.
where is your "x" ie the current request?
