Evoscan v2.4 fixes
Old Sep 16, 2008 | 11:22 AM
  #46
fil78's Avatar
Originally Posted by evo4mad
I fixed the Innovate LC1 logging on the weekend, and also added a LC1 recalibration feature to the EvoScan menu. I will release it later this week.
I was thinking about capping the Wideband results to "20" so that the graph doesn't go out of scale so easily. Do any of you run AFRs greater than 20 that I should know about?
Hamish , 20 is ok for me
let's hope this new version fix the issue that appear to me when upgrading to V2.5 with strange AFR readings (between 3 and 5 ) while Logworks & mitsulogger readings are correct . 'hope you will email the new version this week .
Anyway thanks for your hard work
Old Sep 16, 2008 | 02:03 PM
  #47
fil78's Avatar
PROBLEM FIXED : not an Evoscan bug but an LC1 bug . see here : https://www.evolutionm.net/forums/sh...=366698&page=4
Old Sep 16, 2008 | 11:36 PM
  #48
dbsears's Avatar
Has anybody figured out how to fix logging zeroes in Vista 64bit for 2.4 or 2.5? v.99 works great for me but I want to log my Zeitronix map in evoscan.
Old Sep 19, 2008 | 01:16 PM
  #49
ant_turbo's Avatar
Hey did you fix boost for zeitronix in evoscan 2.4/2.5??
Thanks,,, Im using 2.1 and im getting werid boost readings...
Old Sep 19, 2008 | 04:37 PM
  #50
G20's Avatar
G20
^ I have Zeitronix using 2.5 and it works great.
Old Sep 19, 2008 | 04:49 PM
  #51
ant_turbo's Avatar
Are you logging boost??? anything over 25psi it logs weird!!
Im using 2.1!! I havn't tried 2.4 or 2.5 yet...
Old Sep 19, 2008 | 05:22 PM
  #52
Jack_of_Trades's Avatar
I log up to 30psi on v2.5 with my zeitronix with zero issues.
Old Sep 19, 2008 | 08:46 PM
  #53
ant_turbo's Avatar
Thanks I Will try it
zero
issues.
Old Sep 19, 2008 | 10:54 PM
  #54
dbsears's Avatar
Do you by chance use vista? My XP laptop logs with 2.5 great but my Vista 64bit not so much.
Old Sep 19, 2008 | 11:48 PM
  #55
I use vista 32bit.
supwiddiss
Sep 20, 2017 02:55 AM
isnake
Apr 9, 2017 03:01 AM
evo7girl
May 30, 2009 08:26 AM
evo4mad
Jul 8, 2007 08:27 AM
Quick Reply: Evoscan v2.4 fixes
