EVO Scan Wideband AFR Log fixer!
Hey guys, I have this problem where my Tactrix cable will log faster than my LC-1, so Evoscan will just leave that row blank in the csv file, which screws up the logs when you use the log viewer. So i made a fix . It needs .Net framework 2.0 and just loads the .csv file, parses it into a bunch of strings. Looks to see if the WidebandAF row is filled in, if so it saves the value. If it is not, it just uses the previous value. It starts with a default of 14.7 If the first row is blank. Here are some screen shots.
Before:
After:
Here it is --> https://www.evolutionm.net/forums/at...1&d=1217779830
Let me know if any problems/errors/it screwed up my log stuff happens.
Before:
After:
I already talked with Evo4Mad and discussed the problem and ways to fix it.
I only log like 5 things when i run, Engine rpm , load, afr, knock, timing adv, throttle pos. And at 150+ samples a second, the lc-1 just cant keep up (its running at 9600baud i believe) while the tactrix runs at 15625 baud. So i dont get an LC-1 sample every line.
codgi, i took the index of the column named "WidebandAF". Then when you parse the file, for every value at column "index" i check it, thats the wideband afr column. If you want the source code, its like a page long. Really simple.
must be because the LC1 logs slower than the vehicles ecu, and leaves gaps, I'll try and fix it for EvoScan v2.6
Regards,
Hamish Ahern.
http://www.limitless.co.nz/EvoScan
http://www.limitless.co.nz/Cables
Regards,
Hamish Ahern.
Titaztik
Aug 30, 2005 04:45 PM
