TephraMOD V5.10
Old Sep 12, 2008, 06:38 PM
  #256
supersnow's Avatar
Originally Posted by tephra
Have you got NLTS enabled? with crap settings? :P
Is enable. I don't know what do you mean by crap settings!
The following line was missing from my 15 definition table:
<scaling name="ThrottlePercentage" units="%" toexpr="x/255*100" frexpr="x*255/100" format="%.0f" min="0" max="100" inc="1" storagetype="uint16"/>
Do you think this has anything to do with my problem?
Old Sep 12, 2008, 06:39 PM
  #257
tephra's Avatar
Perhaps your clutch switch is not connection properly.
Try disabling NLTS (just temporarily) and verify thats not causing your problem.
Old Sep 12, 2008, 07:10 PM
  #258
supersnow's Avatar
Thanks a lot.
Of course it was the clutch switch since I never bought one.
Thanks's for the patch....I'll send the donation shortly.
BTW, do you have boost settings for the GM 3P?
Old Sep 12, 2008, 08:18 PM
  #259
tephra's Avatar
start with 40% WGDC, turn off TBEC (zero it out) then slowly increase WGDC after doing a pull...
its pretty easy
Old Sep 12, 2008, 08:29 PM
  #260
supersnow's Avatar
its pretty easy
Yeah I'm working on it....I just hate to waste gas!
The clutch switch must be in need of adjustment, I'm looking for a thread with pics or instructions on how to adjust that stupid switch. If you have the link for one...post away!
Thanks!
Old Sep 12, 2008, 08:53 PM
  #261
tephra's Avatar
my WGDC (and every car is different) starts at 70% up until about 4500 and then start going upto 100% by 7000
Old Sep 12, 2008, 09:50 PM
  #262
mfr122887's Avatar
Originally Posted by Jack_of_Trades
Try this perhaps:
Code:
<DataListItem DataLog="N" Color="" Display="Alt Map Activation" LogReference="AltMapActivation" RequestID="E3" Eval="x" Unit="unit" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="20" ChartMin="0" ChartMax="20" ScalingFactor="10" Notes="" Priority="1" Visible="False" />
Only because I'm certain this works. I already edited the requestID for you. You used "E" from the y asis and 3 from the x axis I assume.
Yes that is how I have entered it into the MUT table. I tried with your settings and it gives me the same value: 255.
Old Sep 12, 2008, 11:12 PM
  #263
tephra's Avatar
8429... 0 for normal maps, 3 or 4 for altmaps.
Old Sep 13, 2008, 10:45 AM
  #264
mfr122887's Avatar
Replaced 8425 with 8429 in the MUT table, reflashed the car and I am still getting 255.
Old Sep 13, 2008, 04:19 PM
  #265
tephra's Avatar
email me your ROM... <myforumname> @ gmail
Old Sep 13, 2008, 04:29 PM
  #266
mfr122887's Avatar
Sent
Old Sep 13, 2008, 04:35 PM
  #267
EvoM Community Team
fostytou's Avatar
Ok, so dumb question and I don't remember if this has been covered yet.
We know the ECU is always looking at high timing map #1 and #2 (and low when your octane value is lower) in the original rom and we have eliminated #2&3 for mods. So for a stock timing map should we average these maps in the base map included in the file?
ie ((high #1 cell 1A) + (high #2 cell 1A)) /2
Old Sep 13, 2008, 05:48 PM
  #268
Darwinn's Avatar
88840017 please... : )
Old Sep 14, 2008, 04:31 AM
  #269
leecavturbo's Avatar
is the non ICS restore bug only on certain roms?
inparticular the recently patched 96260009
Old Sep 14, 2008, 11:19 PM
  #270
evo8dad's Avatar
Anyone else having difficulties getting NLTS to work with the 06 ROM? I've tried several times on a car and no luck. I downloaded it several times and made new ROMs several times but, all to no avail???
Quick Reply: TephraMOD V5.10
