TephraMOD V5.10
Old Sep 29, 2008, 05:26 PM
  #346
ciobing's Avatar
Load 2Byte works in evoscan with v5.10?
Old Sep 29, 2008, 06:28 PM
  #347
tephra's Avatar
yes rpm/load/airflow should just work from the get-go.
however its preferable if you use 1byte load mod...
Old Sep 30, 2008, 07:12 AM
  #348
ciobing's Avatar
(...<scaling name="1bytefactor" units=.... <table name="2byte to 1Byte...)
With any modification to the 5.10 xml file?
Old Sep 30, 2008, 08:40 AM
  #349
steadly2004's Avatar
<DataListItem DataLog="Y" Color="" Display="Load 1Byte" LogReference="Load1B" RequestID="41"
Did you read the first post?
Just add it to the data.xml file in evoscan
Old Sep 30, 2008, 09:13 AM
  #350
Jack_of_Trades's Avatar
What exactly is the 1byte load mod anyways?? Just more accurate to what the ECU is using for its values?
Old Sep 30, 2008, 09:16 AM
  #351
I have a question about ROM 94170015. Is the address correct for the stationary rev-limiter? Because it shows 7969 as the limit and when I change it there is no difference. It just revs to the "rev-limit" number. I tried setting it really low, like 3000 rpm. I put it back incase it was changing something else.
I'm wondering if this changed because of the valet-mode option?
Old Sep 30, 2008, 11:32 AM
  #352
Its the correct address in my copy of the 94170015 v.510 ROM.
Old Sep 30, 2008, 12:08 PM
  #353
Lancerguy'03's Avatar
any possible release dates for ROM ID 96420007 in V5.1 or better?
Old Sep 30, 2008, 12:17 PM
  #354
MR Turco's Avatar
Lancerguy. Tephra is working on a 96420011 version of 5.10 which will work on your ecu.
Old Sep 30, 2008, 01:15 PM
  #355
Is it 2b4a on your definition? Also, do you have the valet-mode on? I'm thinking that if its enabled but not turned on, then maybe its disabling the stationary rev-limiter?
Old Sep 30, 2008, 02:01 PM
  #356
Yeah. Scaling = RPMStatlimit too.
Old Sep 30, 2008, 05:12 PM
  #357
lan_evo_mr9's Avatar
I finally got the patch to work with vista! Except I get this error message when I try to open my ROM now. Parse error at line 401, column 154:
unknown table data storage endian type [BIG].
Any ideas on how to go about this?
Old Sep 30, 2008, 05:49 PM
  #358
That means you have an error in your XML file on line 401, column 154. When you open the XML in Notepad, you'll notice as you move the cursor down the page your line and column # appear in the bottom right hand corner of notepad. Find out exactly where line 401 and 154 is and see whats wrong. Maybe BIG needs to be lowercase.
Old Sep 30, 2008, 05:56 PM
  #359
YOU ARE THE F'N MAN! I've been trying to do this for about a month now and it finally works! It's a celebration *****es! Thank you for everything, time, and help.
Old Sep 30, 2008, 06:01 PM
  #360
tephra's Avatar
Jamie - 1byte load is just 2byte load squished into 1byte.
Just saves on logging speed and the out of order HB/LB problem (leads to spikes in load graph)...
Quick Reply: TephraMOD V5.10
