TephraMOD V5.10
#31
I tried to set up this mod for a friend. On my mac ecuflash 1.34 everything was great, I set it up properly with all the mods, code done properly, saved it, and emailed it to him. When he opens it with PC version 1.35 he has the table of mods, but all the default values are changed.
Example my valet rev limit was 114, his is 273. He was also missing map averaging from the table for some reason. Other values were random like 65535.
Once all the values are properly entered, will it work correctly or has something gone wrong?
Thanks.
Thanks.
#34
Your friend is not using the new xml files which is why his values are are showing incorrect.
#35
Installed this on a friend's car tonight (88590015) running fine on v5.0, and his car will not idle at all. I double and triple checked all of the values that I brought over, and all seem correct. This car also has the direct boost, LC-1/wideband/mrfred, and egr delete mod. Could these other mods be running over each other?
#37
Jordan, as cossie mentioned, your friend needs to update his xml files for the 5.10 version.
Because of this, his ecuflash is referencing the wrong areas of the rom, thus getting incorrect values
#41
thanks!
#43
Values showing up as ... is usually an XML problem (from what I've gathered in these threads). Either you missed some when you were adding the new code, or your endian is wrong (which would probably botch a lot more tables).
