TephraMOD V5.10
Old Oct 14, 2008 | 08:58 PM
  #466
fixem2's Avatar
Originally Posted by tephra
wasn't it:
1.30 and below = little
1.31 and above = big
Tephra is right on the above. Made the mistake a couple times so it is burnt into memory!
Old Oct 15, 2008 | 06:03 AM
  #467
mlocatel's Avatar
Hello Tephra
do we have any chance to get the 88840017?
Thanks
mlocatel
Old Oct 15, 2008 | 06:18 AM
  #468
MR Turco's Avatar
I should be testing 96420011 on thursday, thanks tephra!
Old Oct 15, 2008 | 06:36 AM
  #469
tephra's Avatar
soon mlocatel
Old Oct 15, 2008 | 07:36 AM
  #470
AlwaysinBoost's Avatar
ported everything over for the new v5.10 file last night, just haven't had a chance to flash the ECU and test everything out yet. hopefully tonight I'll have some free time.
Old Oct 15, 2008 | 07:49 AM
  #471
MR Turco's Avatar
I am working on the 96420011 map and i realized that none of the MAP tables for the JDM MAP definitions are supported. Crap...
Old Oct 15, 2008 | 03:17 PM
  #472
Mellon Racing's Avatar
there seems to be a bug in the definition file for 96530006 for injector voltages I'm getting some crazy numbers:
56.25
65.625
70.3125
75
79.6875
84.375
89.0625
Old Oct 15, 2008 | 03:43 PM
  #473
fixem2's Avatar
Mellon, wierd I did not have that issue when I swapped mine into 96530006. I can post a screen shot of my voltages later.
Old Oct 15, 2008 | 03:51 PM
  #474
logic's Avatar
The EcuFlash definition for 96530006 is wrong for Injector Battery Voltage Latency Compensation. The correct definition for it is:
Code:
<table name="Injector Battery Voltage Latency Compensation" address="37c0">
	<table name="Battery Voltage" address="67f0" elements="7"/>
</table>
Old Oct 15, 2008 | 05:51 PM
  #475
fixem2's Avatar
I have EcuFlash 1.38 and the definition is good. I converted to the 96530006 ROM at version 1.35 and the xml was correct. Wonder if this is older versions only.
Mellon, what Ecuflash version are you using?
Old Oct 15, 2008 | 10:30 PM
  #476
THUB's Avatar
Quick question with the mod options table where it says "enable alt. maps master? ADC0F=1 autoICS=2" What is ADC0F? Also, this line just enables/disables alternate maps altogether correct?
Old Oct 16, 2008 | 07:40 AM
  #477
Jack_of_Trades's Avatar
ADC0F means you are using the un-used analog-to-digital input on the ECU harness to switch maps manually rather than use the Intercooler sprayers 'AUTO' mode switch to switch between maps (some cars dont have this luxury). Setting the option to zero disables map switching all together.
Old Oct 16, 2008 | 08:03 AM
  #478
I'm using 1.34, I'm not quick to adopt new versions because I can't afford to run into issues, it slows me down to a crawl
Old Oct 16, 2008 | 02:26 PM
  #479
evo828's Avatar
the 96530006 should be OK on this link
http://evoecu.logic.net/images/1/16/...new_tables.zip
Old Oct 16, 2008 | 02:33 PM
  #480
cool thanks, I've got a race Friday night so I don't want to tamper with it right now but maybe I'll get to it this weekend.
Quick Reply: TephraMOD V5.10
