TephraMOD V5.10
Old Nov 14, 2008, 11:03 AM
  #586
Mellon Racing's Avatar
Originally Posted by Jack_of_Trades
Well I FINALLY remembered to bring my laptop with my on my commute to work to record the low load knock I have been getting. Maybe someone can see something I dont? I added a link below the image for the Evoscan file so anyone can look at it in a graph or in Excel.
LINK TO FILE
have you tried adding more fuel yet? mid 13's AFR where that knock crops up sometimes
Old Nov 14, 2008, 02:46 PM
  #587
MR Turco's Avatar
jamie, can you add RPM to that graph?
Old Nov 15, 2008, 01:02 PM
  #588
Jack_of_Trades's Avatar
I've had it as rich as 12:1 and everywhere in between and I still get it, same with the timing. Sucks trying to get rid of it.
If you DL the file you can see everything. In that log I was cruising just above 3k rpm in 5th and just lightly got on the gas to build a little boost. So roughly between 3K and 3.5k every time you see knock on the chart.
Old Nov 16, 2008, 10:11 AM
  #589
xpro's Avatar
I finally tested 8857008 and works fine.
One problem i have that low ignition map keeps overwriting my ALT WGD 1 and 2.
say for example if i set my alt wgd 1 and 2 it will overwrite Alt low ignition map, and then if i change my wgd it will overwrite my ignition map.
Any cures for this??
Thanks
Old Nov 16, 2008, 10:23 AM
  #590
cossie1's Avatar
Thanks
I had the same issue, if you download it again from page 1, you will see tephra has redone it and realised a fixed version
Old Nov 16, 2008, 10:33 AM
  #591
Duh Panda's Avatar
can someone add this patch to my rom damnt... its confusing
Old Nov 16, 2008, 12:18 PM
  #592
bchappy's Avatar
^ it is not hard there are videos showing you how to do it on the first page I believe.
Old Nov 17, 2008, 03:49 PM
  #593
Oki Panoki's Avatar
just to check. what rom id should i use if my ecu says 94170008. what versions are out for my ecu?
Old Nov 17, 2008, 05:17 PM
  #594
tephra's Avatar
94170015
Old Nov 17, 2008, 05:20 PM
  #595
Oki Panoki's Avatar
Originally Posted by tephra
94170015
really thanks! what is up with that. how do the rom IDs work. or is this mentioned somewhere
Old Nov 17, 2008, 05:21 PM
  #596
tephra's Avatar
its common understanding that the first 4 are some region/model identifier last 4 are possible version of the ROM.
ie 94170008 is earlier than 94170014 which is earlier than 94170015
same deal for 88590013 -> 88590014 -> 88590015
however 88590014 is DIFFERENT to 88580014
Old Nov 18, 2008, 02:45 AM
  #597
xpro's Avatar
thanks pal,
Old Nov 19, 2008, 03:56 PM
  #598
Creamo3's Avatar
Tephra- thanks for all your support and hard work. I am really loving tuning the stock ecu w/ your mods.
I sent you a donation; enjoy a case of beer and burger on me
Old Nov 19, 2008, 04:03 PM
  #599
tephra's Avatar
Thanks man.
I am putting donations towards a BBK at the moment, so hopefully I will get one for chrissy
Old Nov 19, 2008, 05:30 PM
  #600
Evoryder's Avatar
what's a bbk?
Quick Reply: TephraMOD V5.10
