TephraMOD V5.10
Old Nov 30, 2008, 04:37 PM
  #646
EvoM Moderator
joedr's Avatar
Here how my settings are showing on the rom!
Is that how the Alt maps settings should look like?
Old Nov 30, 2008, 04:39 PM
  #647
tephra's Avatar
yeah that should work.
what ROMID are u? I will give you the ADC variable to log to make sure you are getting a proper signal..
Old Nov 30, 2008, 04:41 PM
  #648
tephra's Avatar
actually just log MUT83 - you should need to set it up (so long as you havn't over written 83 before)
that should be the voltage in 255, ie 128 = 2.5 volts, 255 = 5v, 0 = 0v..
Old Nov 30, 2008, 05:39 PM
  #649
EvoM Moderator
joedr's Avatar
Ok! I logged MUT 42 after modding the rom. I am getting 0 with the switch off and 4 with the switch on. Is this correct?
I did change the IGN tables at idle between maps and the car seems to react to changes in timing.
I am getting 4.69 VDC with the switch on in pin 64. BTW, I am on 88590015!
Old Nov 30, 2008, 06:04 PM
  #650
tephra's Avatar
4.69 should equal about 240 not 4... dodgey connector maybe?
Old Nov 30, 2008, 06:40 PM
  #651
EvoM Moderator
joedr's Avatar
I will verify tomorrow again and report!
Old Nov 30, 2008, 11:46 PM
  #652
eiu2b's Avatar
"using the faa periphery bit?" i don't know what is it?
i only tried to put "FFFF"and i don't work, i lost my code imobilizer.
that's why i use only ralliart map.
Old Dec 1, 2008, 03:20 AM
  #653
tephra's Avatar
ok you need to add this to your 96530006.xml
Code:
<table name="ECU Periphery0 Hex" category="Periphery" address="faa" type="1D" level="2" scaling="Hex16"/>
Then in ecuflash change it from 0x56DA to 0x56D2 - if its not 56DA to start with post it up and I will tell u what to change it too.
Old Dec 1, 2008, 07:57 AM
  #654
eiu2b's Avatar
ok, i do this, i put 0x56D2, but now what i put in my imobilizer code? nothing or "FFFF" like a ralliart map? because i lost my code.
thanks.
ps: it was ok, ecuflash tell me 56DA.
Old Dec 1, 2008, 07:59 AM
  #655
logic's Avatar
Once you've changed Periphery0, you can set the immobilizer code to anything at all; the change tephra had you make disabled the immobilizer entirely.
Old Dec 1, 2008, 08:00 AM
  #656
eiu2b's Avatar
and in the patch i put 0x56D2 too?
Old Dec 1, 2008, 11:10 AM
  #657
eiu2b's Avatar
ok, i put it in but why tephra mode the car don't start.
Old Dec 1, 2008, 11:54 AM
  #658
silver9mr's Avatar
PLEASE HELP TEPHRA!!!!! well iv been trying to get an inspection sticker on my car for the last month now and all i could come up with is that the rear O2 deleat cheat is screwing me up so can u confirm somthing for me.... well here in massachusettes i need an OBD2 check to get a stick and when the computer gets hooked up to my car i need a readiness code sent to his comp from the
1.O2 sensor
2.O2 sensor heater
3.catalyst
which all 3 are sent to the comp saying not ready.. so my question is when this o2 deleat is patched in is it now imobilized from sending out any codes to an obd2 scanner for an emmisions check
thanks in advanced for any help .. i just dont want to take my exhaust off again to take my wide band out lol
Old Dec 1, 2008, 01:33 PM
  #659
steadly2004's Avatar
1.O2 sensor
2.O2 sensor heater
3.catalyst
Sounds like you turned off the rear 02 with the periphery, which turns the rear O2 to not ready and the catalytic converter also. I suggest you turn it back on, and if you don't have a rear O2 installed, get the right resistor. Also, turn on tephra's rear O2 simulator to pass the catalyst test. That should address all 3 problems.
And download/install scantech so you know when everything passes before making another trip to an inspection station.
Old Dec 1, 2008, 02:34 PM
  #660
tephra's Avatar
ei2ub - make sure Autovalet option is DISABLED...
silver - yeah dont do the faa periphey bit2 disable...
Quick Reply: TephraMOD V5.10
