TephraMOD V5.10
Old Jan 3, 2009 | 08:30 AM
  #736
gear head's Avatar
Just the top one(0xffa)
Old Jan 3, 2009 | 12:02 PM
  #737
Evo8uk's Avatar
Ok cheers i'll give it a go later. Is it known yet what the other entries do in that table yet?
Old Jan 3, 2009 | 12:07 PM
  #738
grayw's Avatar
It modification to pheriphy bit works fine, the immobiliser can be reactivated on 96260009 when used on a normal GSR.
Old Jan 3, 2009 | 12:54 PM
  #739
Evo8uk's Avatar
Just been out and tested this but unfortunately does'nt seem to work as planned, I set the faa back to stock so the immob is effectively back on and with the change to the ffa periphery the car will start but then if you change the immob code it will still start so this change to ffa seems to disable the immobiliser the same as if the change was made to faa
Old Jan 3, 2009 | 05:16 PM
  #740
Evo8uk's Avatar
Is there anything else i could try to get the immobiliser working again I know its not really a major issue having it disabled but with this kind of car any extra security feature is a bonus.
Old Jan 3, 2009 | 06:39 PM
  #741
tephra's Avatar
so you are saying that with the FFA bits set the same and the FAA bit re-enabled you can put ANY immob code in and it starts?
Old Jan 4, 2009 | 05:02 AM
  #742
Evo8uk's Avatar
Yeah i changed the last digit on my immobiliser code and the car still started
Old Jan 4, 2009 | 05:31 AM
  #743
tephra's Avatar
try the first digit
Old Jan 4, 2009 | 06:41 AM
  #744
Evo8uk's Avatar
Just tried it out by changing the first digit in the immobilser code and its still the same the car still srarts.
Old Jan 4, 2009 | 07:09 AM
  #745
xpro's Avatar
Tephra would that be correct value now for MUT request 41?
i added the 3d Mut table to V5.1 rom
Old Jan 4, 2009 | 08:06 AM
  #746
grayw's Avatar
Phil, that's correct
Old Jan 4, 2009 | 03:47 PM
  #747
tephra's Avatar
xpro - yes
evo8uk - what is your faa bit like?
your original romid is 93360005 or something yeah?
Old Jan 4, 2009 | 03:53 PM
  #748
Evo8uk's Avatar
My original Romid is 93660005 and the Faa is 0x56D8
Old Jan 4, 2009 | 03:55 PM
  #749
tephra's Avatar
hrmmm.... not sure then. Maybe grayw can check it on one of his cars - but maybe it just *doesn't* work on 93360005
Old Jan 4, 2009 | 04:00 PM
  #750
Evo8uk's Avatar
Is it just ffa & faa that control the immobiliser part of the rom or is it a lot more complicated than that?
