TephraMOD V5.10
#781
hey tephra are the 1byte load, 2byte load, 2byte rpm and 2byte airflow mods patched into your 96260009-v5.10fix2-mods.bin rom. i only see entries in your xml def for the "2byte to 1Byte Load Factor" mod but no xml for the 3D MUT Table so that i can verify. Jack_of_Trades does not have the 3D MUT Table address or the 2byte MUT addresses listed for 96260009 on his thread. do you know where i could find this information?
#784
Using the wife's computer which uses the POS MS Vista, it will not allow me to save the XML document after I made changes. It wants me to "Make sure the path and file name are correct".
I do not normally use Vista since my Mac runs Boot Camp and I use XP on that side. Something I may be overlooking since I'm not a Vista buff?
-E
-E
#786
-E
-E
#788
change user permissions.
-E
-E
#789
1. Since installing the patched rom 96530006 my car will stumble sometimes when going back to idle. example let the clutch out to pull forward a few feet then press the clutch in. the idle will drop down to a few hundred rpm. i dont know if it is related to the rom or the full ETS IC kit. I will flash back to the 96400011 rom tomorrow to see if it still stumbles. i have scaled the maf since i installed the parts.
2. i am getting a lot of part throttle knock when transitioning to open loop. again i will see how the cars acts with the orig rom.
Has anyone experienced this? I am using Bryan's(Razorlab) XML.
#790
#792
#793
would anyone have any idea why the boost limit tables would be messed up after patching 94170015 rom with 5.10 ? I had to re do everything after my laptop **** the bed and now I am re doing everything. I didnt come across this problem when i did it the first time.
I also checked the rom and I didnt see anything out of place.
Thanks
Jeremy
Thanks
Jeremy
#795
yah actually I am. I have a 03 with the 94170008 rom and I instead used the 94170015 rom with the patch. So where should I be looking to check my boost limit definition ?
I checked the xml to see if the boost limit definition in there matched 94170014 and it did.
Thanks Tephra
Jeremy
Thanks Tephra
Jeremy
