TephraMOD V5.10
Old Feb 6, 2009, 08:17 AM
  #811
Evo8Emperor's Avatar
So atleast I know Im not the only one. I guess as far as the table goes Ill just leave it I guess. I really want to switch over to a gm bcs and get rid of the hks evc.
Old Feb 6, 2009, 03:46 PM
  #812
tephra's Avatar
ive never heard of wastegate compensation b4...
Old Feb 6, 2009, 04:36 PM
  #813
draconx's Avatar
hey when will the new version be out?
Old Feb 9, 2009, 12:58 PM
  #814
b16a95eg's Avatar
i couldnt get the no lift shift to work, i set it up the exact way you said to and it wouldnt work, its the 94170015 ecu, i think thats the right numbers
Old Feb 9, 2009, 01:26 PM
  #815
b16a95eg's Avatar
i downloaded it off the old thread, so that might be why, i'll download it off this one when i get home
Old Feb 9, 2009, 05:48 PM
  #816
b16a95eg's Avatar
hmmm, still couldnt get it to work.. what am i doing wrong? can i show you guys anything?
Old Feb 9, 2009, 05:50 PM
  #817
tephra's Avatar
are the other mods working?
did you flash the modded ROM?
have you enabled NLTS?
what values do you have for the various NLTS related thresholds?
have you done the garage test?
Old Feb 9, 2009, 07:39 PM
  #818
b16a95eg's Avatar
i followed the values you said to use in the other thread, 0km/h, 0% load, 20% throttle, 800rpm drop, and test flashed it to the ecu, but i couldnt get it to work, in the tephra mods options in ecuflash enable no lift to shift has 1 for a value, i'm probably doing something wrong as i'm new to this, i havent tried any of the other mods because i picked what seemed to be the easiest to know if i got it to work
Old Feb 9, 2009, 07:42 PM
  #819
tephra's Avatar
and the values in the ROM b4 u changed them made sense (ie they WERE NOT 65535 or something 'weird')??
so you rev the car to 2500rpm while in neutral then press the clutch ? and nothing happens?
what version of ecuflash you using?
Old Feb 9, 2009, 07:46 PM
  #820
b16a95eg's Avatar
yeah before they made sense, they were like 150% load, 30km/h and 98% throttle. and yeah i have it in neutral rev it to 2500 and push the clutch in, then it just raises up like it normally would, and doesnt stop, i'm using Version 1.41
Old Feb 9, 2009, 08:11 PM
  #821
tephra's Avatar
hrmm...
that is very strange...
u did flash that updated rom to your car?
did it take a long time to flash (the first time?)
email me the rom... myforumname@gmail.com
Old Feb 9, 2009, 08:13 PM
  #822
b16a95eg's Avatar
yeah it took quite awhile, everything is stock on the rom, minus the stuff i changed to try it out, this is going to sound really dumb but how do i send you the rom? lol
Old Feb 9, 2009, 08:14 PM
  #823
b16a95eg's Avatar
would i just like attach it as a file?
Old Feb 9, 2009, 08:22 PM
  #824
b16a95eg's Avatar
i sent it to your name on the forum @gmail, (tephra) right?
Old Feb 9, 2009, 08:42 PM
  #825
tephra's Avatar
got it thx
rom looks ok...
were u getting any CEL's before OR after the flash?
is this your native ROMID or another?
do you have a log of the garage test?
Quick Reply: TephraMOD V5.10
