TephraMOD V5.10
Old Feb 26, 2009 | 09:09 AM
  #856
RyeLou's Avatar
Should I change the knock sum fast to something like 2 or 3?
And I'm still curious what I set "Enable Alts. Maps Master" to after I get the switch installed.
Old Feb 26, 2009 | 06:35 PM
  #857
RyeLou's Avatar
Hmm...I can't even get my car to start with the 96530006. I tried moving over just the timing and fuel maps, did what I thought had to be done with the immobilizer and turned off all tephra mods. No luck. Any ideas on where to start?
Old Feb 26, 2009 | 08:55 PM
  #858
laramie_05MR's Avatar
set cel slow to 3 and fast 5. you can and will get random transition knock 1-2 counts. nothing major. the ecu doesn't pull timing till 3 knock counts.
Old Feb 26, 2009 | 09:26 PM
  #859
RyeLou's Avatar
So there is no multiplier of any kind for knock in those fields? I only ask because the high one was in the mid two thousands. I would imagine if you have that much knock your engine is in eleventy billion pieces..
Old Feb 26, 2009 | 09:57 PM
  #860
no multiplier for knock
Old Feb 26, 2009 | 10:09 PM
  #861
RyeLou's Avatar
Thanks for the help over here too :thumbsup: I'll report back tomorrow with what happens.
Old Feb 28, 2009 | 08:57 AM
  #862
Danieln's Avatar
Please help me with 88840013 ROM - high consumption
Hello Tephra and to all the members of EVOm.
Now i ask for your help with a issue that i encounter with my Evo 9 2006 EDM 6 speed with the ROM series 88840013.
Please tell me if I can switch between the ROMS (88840013 to 88840016 or 88840017) if I change only the immobilization code.
2007 ROMS are suitable for my EVO9 2006??? (88580014)
If you have time, please have a look at my thread.
Thank you
https://www.evolutionm.net/forums/6752375-post1.html
Last edited by Danieln; Mar 1, 2009 at 02:05 PM. Reason: delete the post because i put it in another thread
Old Feb 28, 2009 | 10:19 AM
  #863
fixem2's Avatar
I don't see your ROM attached, but it would be of great benefit if you took a log of your car, so we can see what is going on.
Old Feb 28, 2009 | 04:46 PM
  #864
Danieln's Avatar
I have attached my ROM file.Please use Winzip 12.0 for decompress.Have a great day!
Old Feb 28, 2009 | 08:20 PM
  #865
tephra's Avatar
dude - create a new thread
also use paragraphs otherwise people will just ignore you
Old Mar 1, 2009 | 03:14 AM
  #866
Danieln's Avatar
Hi Dave....
Thanks for reply and sorry for posting wrong.
This is the link for my thread.I still need your help about this if you have time.
Take care
Old Mar 1, 2009 | 02:36 PM
  #867
RyeLou's Avatar
In an email with tephra he said to try setting the knock threshold for fast CEL to 150, so there must be something going on.
Old Mar 1, 2009 | 03:11 PM
  #868
are you talking about Load required for CEL on knock? then set that to 150 or so. this means the CEL will only flash when you are in open loop and will not flash when the ecu transitions from closed to open.
Setting Knocksum for fast CEL to 150 would mean the CEL would never flash the max knock the ecu will record is 36 counts.
Sorry for missing the auto refresh valet option. i disabled that before i tried starting my car the first time.
Laramie
Old Mar 1, 2009 | 03:58 PM
  #869
RyeLou's Avatar
Yeah sorry load is what it was. 3/6 is what I'd set the knocksum counts at.
I'm a little flustered with all this to be honest. I might try again later this week, but for now I have my old ROM in. I changed the valet to 1 and car wouldn't start. Put it back and still nothing. I've had auto valet at 0 this whole time. Just doesn't make sense.
Old Mar 1, 2009 | 04:29 PM
  #870
tephra's Avatar
sometimes the valet thing can lock you out... can you try this:
flash autovalet = 0, valet = 1
see if car starts?
if not then ign on - hold TPS down until the slow CEL flash
see if car starts?
Quick Reply: TephraMOD V5.10
