TephraMOD V5.10
Old Mar 1, 2009 | 04:33 PM
  #871
RyeLou's Avatar
I'll walk outside now and give it another shot. Will update this post in a minute.
Edit: Didn't work with auto set to 0 and valet set to 1. Didn't work with auto set to 1 and valet set to 0. Didn't work with everything set to 0. I couldn't even get the CEL to flash. I held it for up to 30 seconds and it just stayed solid (like it does with ignition on, car not running)
See it doesn't make sense to me. I can have everything set to 0's for tephra mods and when it was working I'll still have to use the pedal to start my car and the CEL will still flash for knock.
Old Mar 1, 2009 | 05:00 PM
  #872
tephra's Avatar
are you flashing the changes back to the car?
what was the result of that little proceedure I gave you b4?
Cheers
D.
Old Mar 1, 2009 | 07:04 PM
  #873
RyeLou's Avatar
Yeah, between each change I uploaded it back into the car.
The results were what I posted above. Car turns over but will not start.
Old Mar 2, 2009 | 03:48 AM
  #874
Yorgis_MR's Avatar
Quick question...is the 9653006 ROM on the first page, the most updated version? (I am asking because people are ironing-out bugs and I am not sure if it gets updated accordingly). Tephra?
Old Mar 2, 2009 | 04:07 AM
  #875
tephra's Avatar
should be
what romid u coming from 96940011? dont forget the immob fix
Old Mar 2, 2009 | 04:08 AM
  #876
tephra's Avatar
once the valet mode is disabled (assuming you have autovalet = 0) then it should stay off..
sometimes after you flash it will reenable...
just turn it off, and I will try and fix that bug (96530006 only??)
Old Mar 2, 2009 | 06:48 AM
  #877
Yorgis_MR's Avatar
Originally Posted by tephra
should be
That would be correct...and even though I dont have a CLUE what you guys are talking about half the time, this thread has been VERY helpful, so thank you!
Old Mar 13, 2009 | 07:41 PM
  #878
Jack_of_Trades's Avatar
Tephra, you have gmail.
Old Mar 13, 2009 | 07:58 PM
  #879
FastAzzEvo's Avatar
what is the link for the most up to date instructions on applying these mods?
Old Mar 14, 2009 | 07:36 PM
  #880
wesside's Avatar
Finally hooked up jacks harness and updated on v5.10 with ecu boost control, everything is working fine but the ecu isnt responding to alt-map switching. pinned 42 there wasnt any pin i had to take out so was just pin and set everything up. led goes on and off like it should but its not switching maps
am I the only guy with a 05 rs moved to the edm 96530006? my friend said he had to remove a pin in his ecu to put the pin in?? mine was already empty
Old Mar 14, 2009 | 07:52 PM
  #881
tephra's Avatar
not sure on the pins - I wouldn't worry if there wasn't a pin there... just double check you got the right pin
Can you log MUT83 - that's the voltage (formula = x*5/255) being appiled to the pin.
you should be able to see it going up/down when you switch the switch
Do you have MasterAltmaps = ADC0F (2???)
Old Mar 14, 2009 | 10:35 PM
  #882
wesside's Avatar
We figured it out **** blame it on me and my friend just not paying enough attention and huge hangover day prob shouldn't have been doing so much evo work today
it was the alt map load threshold and alt map time to activate values that we changed that we should've left alone
I have MasterAltmaps ADC0F (1)
Tephra mod altmap switching and ecu control boost FTMFW so much better of a failsafe system then cutting boost to wastegate as well as having a non methonal map to switch too. I'll do more testing tomorrow I'm burnt out
Old Mar 15, 2009 | 03:55 AM
  #883
tephra's Avatar
good on ya
just curious what romid?
Old Mar 15, 2009 | 01:25 PM
  #884
EVOIXreno's Avatar
ok I want to know if there is a step by step on what to delete and what to replace... kinda like a tephra mod for dummies..LOL
Old Mar 15, 2009 | 04:27 PM
  #885
wesside's Avatar
good on ya
96530006 now just playing with ecu boost control with my mac valve...think I might ditch it for a gm 3port. Love having map switching now though
Quick Reply: TephraMOD V5.10
