TephraMOD V5.10
Old Aug 12, 2008, 09:08 AM
  #91
j3llyh34d's Avatar
I too would be interested in knowing the wiring required to add a 2nd clutch switch....
Old Aug 12, 2008, 09:15 AM
  #92
cossie1's Avatar
On a 7 ecu I think it would need to go into pin 43, as that is the pin used looking at the evo 8 260 ecu pinout.
But it doesn't say if that is the top or bottom clutch switch.
Old Aug 12, 2008, 09:26 AM
  #93
xtremeIX's Avatar
I integrated the XML code into ECUFLASH for 88590015 and all the values were showing correctly in ECUFlash except for the NLTS TPS Threshold which showed as '...' To resolve this I had to add the following line of code in the 88590015.xml file:
<scaling name="ThrottlePercentage" units="%" toexpr="x/255*100" frexpr="x*255/100" format="%.0f" min="0" max="100" inc="1" storagetype="uint16"/>
I won't be able to test it in my car until tonight to ensure everything is working correctly.
Old Aug 12, 2008, 09:47 AM
  #94
sub7's Avatar
Yeap, pinout 43 that is. On evo IV-VI, do you have to step on the clutch before crank to start? VII have that switch. I wonder if I could relocate that switch to upper and ecu pin to 43 can do the trick. :P
Old Aug 12, 2008, 09:51 AM
  #95
cossie1's Avatar
No on the 4-6 there are no clutch switch's at all
Old Aug 12, 2008, 12:09 PM
  #96
EvoM Community Team
fostytou's Avatar
Added some pre patched roms to the wiki for 88590015:
https://www.evolutionm.net/forums/sh...7&postcount=54
There's base v.10, JDM MAP, and Direct Boost Control.
Old Aug 12, 2008, 12:18 PM
  #97
PessimiStick's Avatar
Originally Posted by tephra
hey dudes - just quickly on the "..." issue.
basically thta means the scaling isn't defined properly.
check your XML/evo9base.xml to make sure "ThrottlePercentage" is defined...
ThrottlePercentage isn't defined in evo9base.xml with EcuFlash 1.35.
I added it from the XML that cossie posted on page 4 and that fixed it.
(into 88590015.xml)
Also, for the record, the default seems to be 98%, not 100%. =)
Old Aug 12, 2008, 12:21 PM
  #98
fixem2's Avatar
Waiting patiently for 96530006 ROM.
Old Aug 12, 2008, 02:14 PM
  #99
JordanS4's Avatar
When NLTS is enabled, is it fuel cut, ignition, or both? Just wondering for that time when the TB is open and air is still going in does this create a lean spot?
Old Aug 12, 2008, 03:37 PM
  #100
joyce1bro's Avatar
No idea at all as it works fine for me.
Are you 100% stationary when you try it ?
You can email me your rom if you like and i'll take a look at it.
ok i'll pm you to get your e-mail so i can send the ROM. and yeah i was stationary (actually i was parked and i just wanted to see if it worked) there's no special trick to it aye?? just stop and rev?? i dont need to be in gear or do anything else????
thanks cossie
Old Aug 12, 2008, 03:47 PM
  #101
cossie1's Avatar
No there is no need to do anything special.
Just be stationary and hit the throttle.
If your gentle on the pedal it just bounces off the set limit, if you hit the throttle hard it will bounce off the set limit and build a little boost
Old Aug 12, 2008, 05:12 PM
  #102
joyce1bro's Avatar
^^ mmmm interesting... i will try again and see what happens....
Old Aug 12, 2008, 05:23 PM
  #103
TouringBubble's Avatar
Tried out 88590015 a bit ago ... 1-byte and MAP averaging seem to be working well. I didn't test other features yet.
Old Aug 12, 2008, 05:24 PM
  #104
tephra's Avatar
UPDATE FOR 90550001
5.10fix version is up - only for 90550001 as we implemented a special "stationary rev limiter".
Old Aug 12, 2008, 05:27 PM
  #105
JordanS4's Avatar
bump for an answer to post #99
Quick Reply: TephraMOD V5.10
