TephraMOD V5.10
Old Jul 20, 2009, 08:01 AM
  #1096
rawkus's Avatar
I can log the ZT2 via Mitsulogger and the Zeitronix software perfectly fine. It will not work with EvoScan and also causes all the normal EvoScan logs to read randomly.
Also, EvoScan doesn't seem to read load properly regardless, it normally reads very low (max 160).
Dan
Old Jul 20, 2009, 08:17 AM
  #1097
Appauldd's Avatar
Reinstall EvoScan.
Old Jul 20, 2009, 09:23 AM
  #1098
rawkus's Avatar
Reinstalled, same problem...
Thanks.
Dan
(Tried changing COM Port settings on the USB to Serial Adapter, no luck)
Old Jul 29, 2009, 09:12 PM
  #1099
JordanS4's Avatar
I'm having a very strange issue. I have used the TephraMOD before on my ECU successfully but for some reason now, I can't get some of the features to work on my car. I have tried the original NLTS+Valet+Knock Light Patch, 5.10, and V6, and none of them work correctly. After manually patching over the XMLs at first, I am now using "fostyou's" prepatched V5.10 rom. I installed both the ECUFlash and EvoScan components, and when I open up ECUFlash all the tables for the mods show up. I made all the parameters correct and flashed it onto the ECU with no problems reported. However the NLTS, knock light, and Valet features do not function correctly. 2 byte load however, does. I am not sure what to do as I have tried everything I could think of, reinstalling and uninstalling, test writing, using fresh maps, and nothing can get all the features to work despite some functioning and me seeing no problems in ECUFlash.
Thanks
Old Jul 29, 2009, 10:35 PM
  #1100
evo4mad's Avatar
Dan
Reinstall Beta19 yes this is because EvoScan was choosing the wrong FTDI cable for ecu logging, it was thinking the wideband was teh car ecu, and thought the op1.3u cable was the wideband, this has now been fixed. try latest version.
Old Aug 2, 2009, 05:10 PM
  #1101
EvoDan2004's Avatar
i try to copy and paste the info from the v5 to the 0015 rom id and it wont let me save it. keeps telling me to make sure the name and path is right or something.
this is on vista 64. anyone with a little help?
Old Aug 2, 2009, 09:08 PM
  #1102
kaj
kaj's Avatar
right click on the file you have stored on your computer. go to:
properties> security>
click "edit" under "change permissions".
select the "group" or "user name" you're currently using.
be sure all boxes under the "allowed" section are checked. you may need to check the "full control" box.
now you can edit the file. i have to do this pretty much EVERY time i try to edit a rom file. it's annoying.
Old Aug 2, 2009, 09:34 PM
  #1103
kaj
kaj's Avatar
k. here's where i keep getting lost.
the page reads
" Remove/Rename your current "Boost Desired Engine Load" #2 and #3, only #1 matters anymore"
i'm assuming it means get rid of tables 2 and 3 'cause only 1 will be used.
but all i see is this:
<table name="Boost Desired Engine Load (High Gear Range)" address="3f80">
<table name="RPM" address="722e"/>
</table>
<table name="Boost Desired Engine Load (Low Gear Range)" address="3fb2">
i do not have 1, 2, and 3. i just have high and low gear. am i missing something in the rom?
Old Aug 8, 2009, 01:04 AM
  #1104
QwikEVO's Avatar
Ok, maybe I'm late in the game and tried to sort through all these threads for the answer...but I can't find the 94170008 rom for this Mod.
Is there a new rom i need to convert to, and how do I convert my 94170008 to the new ROM?
Also, I've been reading about the TephraMod table in EcuFlash that has multiple screens (namely the map on the fly mod). I only have three colums in my TephrMod table, and it has nothing to do with the map on the fly mod. Just rev limit switching, flashing CEL on knock, and valet mode.
am I doing something wrong, or did I miss something?
(once again, excuse my n00b ness. I just got introduced to this today)
Old Aug 9, 2009, 10:25 PM
  #1105
kaj
kaj's Avatar
i think i'll leave this up to a tuner. i'm way too far behind the curve on this one. it's impossible to learn anything unless you have someone right next to you pointing stuff out. getting answers via the internet is proving to be pretty tough 'cause nobody wants to answer the "noob" questions.
bleh.
at least the software is free!
Old Aug 9, 2009, 11:38 PM
  #1106
kaj
kaj's Avatar
i keep getting this error, no matter how careful i am:
"parse error at line 464, column 6: tag mismatch". do i REALLY need to count down 464 lines?? LOL
Old Aug 10, 2009, 01:07 AM
  #1107
xpro's Avatar
easiest way out of it to ask someone with the same rom id to send you the tephra xml and then you just map it to suit.
I took me ages to figure this aswell,
Old Aug 10, 2009, 01:20 AM
  #1108
kaj
kaj's Avatar
Lol dee dee dee. That WOULD make sense. Wouldn't it! Haha. K. Anyone have a successfully tephra-modded 0015 map? :-)
Old Aug 10, 2009, 06:35 AM
  #1109
wip
wip's Avatar
Open it in excel or open office
Old Aug 10, 2009, 07:39 AM
  #1110
logic's Avatar
Install Notepad++. It's the Notepad that Windows should have shipped with in the first place. It gives a visual display of line number, and does syntax highlighting (so the colors go screwy when you have a mistake in an XML document, for example).
To your specific problem: like 464 is probably very close to the end of the file. You probably just have one screwed up XML tag somewhere (forgot a closing tag, made a typo on a tag, or pasted a set of tags in the wrong place, that kind of thing).
Quick Reply: TephraMOD V5.10
