TephraMOD V5.10
#1171
Registered User
with 50 i should be @ 20 psi. and 20 puts @ 12 psi. now i am over boosting like my 3 port is switched off (29psi).
TBEC is off. the only thing i am thinking is the values for my secondary/passive solenoids are too high and should be zero.
#1173
Registered User
lol man - u got the 3port vacuum lines backwards.
dial in 80% - I bet you hit 14psi :P
worked very well with map switching and everything!
#1175
Registered User
tephra, i dont think its gonna work cause if i had 50 and i got 29 psi, 80 would be at the same psi, i believe the extra WGDC tables (#1/2, #1/3) need to be zero'd out in order for the 3 port to be controlled by WGDC table #1/1.
IMO, having values in the #1/2, #1/3 is actually keeping the 3 port closed rather than venting to the WGA.
what ya think?
what ya think?
#1177
Registered User
tried it and the same over boosting. i believe its the extra WGDC maps i got
#1179
Registered User
no problem thanks for your time on this, unfortunately, i cannot run any logs, i work on a plant so i am here till Thursday
will post ASAP and will do some extensive testing as well to get to the bottom of this.
on a side note: i realised i cannot use your rom for my JDM, cause the SD is different. on my IX i use the MAT and MAP sensor to run SD, i think on ur rom an IAT is required for SD right?
#1181
Registered User
88580014 was my last rom (with some bits for rear O2, etc) of choice since it has the Tranny temp sensor and AYC/ACD.
88590015 will be way off for my car - no AYC, etc.
#1183
Registered User
#1185
Registered User
okay, okay.. on a stock IX MR, how much boost SHOULD i be seeing? i kid you not... i googled for days and could not find a simple "oem boost" number.
i'll admit i'm not the best at searching.. but dang!
