TephraMOD V5.10
Old Aug 12, 2008, 06:24 PM
  #106
tephra's Avatar
its the same cut as normal rev limiter..
so fuel cut - you should be able to verify this by logging IPW in evoscan
Old Aug 12, 2008, 08:06 PM
  #107
joyce1bro's Avatar
^^cool as
Old Aug 13, 2008, 03:02 AM
  #108
j3llyh34d's Avatar
Dave, thanks again for all the work. Appreciation sent....
Old Aug 13, 2008, 03:23 AM
  #109
joyce1bro's Avatar
^^ + a million
Old Aug 13, 2008, 05:06 AM
  #110
fixem2's Avatar
Donation made. 96530006
Old Aug 13, 2008, 05:11 AM
  #111
tephra's Avatar
thanks dude.
I will try and get 96530006 out tomorrow...
Old Aug 13, 2008, 07:02 AM
  #112
TouringBubble's Avatar
Did some more testing on 88590015 this morning ...
Valet limit working
Map switching working
NLTS working
I did not test the NLTS load threshold though.
I have one question ... I have the valet set time at 3 seconds and the CEL flash for valet at 4 seconds. When testing this morning, I noticed that when you first set valet mode the CEL flashes, but it doesn't flash on subsequent starts if the mode is left enabled. Also, the CEL flashed on disable ... is this correct. The flash on disable confused me a bit ...
Old Aug 13, 2008, 07:10 AM
  #113
tephra's Avatar
ok the deal is (from memory and hopefully right)
on fresh ignition (ie key out for at least 10 secs):
if valet is enabled - then fast flash
if valet is not enabled - then no flash
on manually swapping valet (holding TPS):
if valet has just been enabled - fast flash
if valet has just been disabled - slow flash
So at no time should you see a slow flash on fresh ignition...
This is all regardless of autovalet as that gets setup b4 the flashing is done...
Old Aug 13, 2008, 07:15 AM
  #114
fixem2's Avatar
No problem Tephra, appreciate all the work and help.
Old Aug 13, 2008, 08:06 AM
  #115
dudical26's Avatar
Any chance of combining the v5.10 with mrfreds new front 02 sim?
Old Aug 13, 2008, 08:21 AM
  #116
Alright, got it. I'll pay attention to the flash speeds ... I didn't know there were 2 speeds for the valet limiter.
Anything you specifically need tested on the 88590015 ROM? I've got map switching, psi based boost control, etc. Just let me know.
Old Aug 13, 2008, 09:26 AM
  #117
sub7's Avatar
Added 90550001 in Wiki
http://evoecu.logic.net/wiki/Downloads
Old Aug 13, 2008, 09:57 AM
  #118
dudical26's Avatar
Originally Posted by sub7
Nice work, mind providing a little more info about what is in the file on the file's image page here
http://evoecu.logic.net/wiki/Image:9...10fix-mods.zip
Is it simply a tephra v5.10 rom with instructions (the same file downloaded from the first post in this page?)
Old Aug 13, 2008, 10:04 AM
  #119
sub7's Avatar
Yes it is, the same tephra v5.10 file from first post on this page.
Old Aug 13, 2008, 11:39 AM
  #120
krazykorean84's Avatar
Originally Posted by krazykorean84
Also I had previously been using V5 to eliminate my rear O2 CEL along with the resistor mod but when I switched to V5.10 I got a CEL for P0037 rear O2 heater circuit and there has been no change with the resistor.:
Has anyone with 88590015 tried the rear o2 sim yet?
Quick Reply: TephraMOD V5.10
