Zeitronics and Evoscan ?s
Is there any way to log boost through the ECU (in EvoScan) from my Zeitronics MAP sensor?
Do I need any XML mods in Evoscan or ECUflash to log AFR with the 5v anolog output?
Thanks
Thanks
So, logging AFR via the 5v analog output is no promblem- needs no XML updates.
Anyone know of a way to use the Zeitronix 3.5bar MAP sensor to log through EvoScan and/or control boost?
Ideally I would like to get all my log data into the EvoScan Enviornment.
I guess another question might be how difficult/accurate is it to overlay zeitronics logs with EvoScan logs and get useable data?
Please pardon the Noob questions.
Evoscan will log whatever the zeitronix control module is reading. so, if the zeitronix control module is connected to a wideband and a map sensor evoscan will log it from the serial connection.
I hope this answers your question otherwise I'm totally misunderstanding you.
