OBD-II tables (ecuflash 1.38)
i'm interested can i disable, for example P0505 code(i wont to check dont light on this code), with table OBD-II codes in ecuflash 1.38? or maybe some other code
there are ways to disable some obd codes from by using the ecu periphery bits. It's documented in the ecuflash forums, but it's for users who know what they are doing.
I would suggest fixing the p0505 fault you have.
had the same on my car, turned out my BISS screw was mis-adjusted, and the iac had to work too much and couldn't stay in range of the preset values.
when i got that fixed, it turned up again (3 month later) due to a changed mivec table, and tephra posted a fix for it.
let me know if you played around with you mivec table, i might be able to help you out.
