injector scaling help
Old Sep 16, 2008 | 10:51 PM
Gary@MellonRacing's Avatar
Question injector scaling help
WHEN IM ON FUEL SECTION ON MY ECU FLASH I DONT SEE OR FIND INJECTOR LATENCY can anyone help me on this
i have an evo 4 with evo 8 ecu running 720 injectors , what im trying to do is get rid of safc , i want to adjust the scaling and latency so i can properly tune my car .
Old Sep 17, 2008 | 08:39 AM
tephra's Avatar
romid?
ecuflash version?
Old Sep 17, 2008 | 10:49 AM
ROM ID 94170014
ecu flash 1.35.1650
Old Sep 17, 2008 | 05:23 PM
tephra's Avatar
have you changed your mode to developer?
Old Sep 18, 2008 | 03:35 PM
yes but i needed help on setting the correct injector latency
Old Sep 18, 2008 | 03:42 PM
hellcat's Avatar
I know your injector scaling will be around 608 for 720 injectors. I can't remember where I start tuning those as far as latencies are concerned, but there are plenty of good starting points here if you search a little. Do you know how to fine tune them once you find a good starting point? You need to log your fuel trims once you get the values to make sure they are right. Remember, it takes a few minutes of idleing or driving for the values to change and you want them to be as close to +5 or -5 as possible. I hope this helps.
Fast_Freddie
Oct 30, 2023 02:56 AM
foxbat
Jun 1, 2016 04:02 AM
philr8
May 24, 2013 01:45 AM
lncrphish
Lancer Engine Management / Tuning Forums
15
Aug 3, 2010 07:48 AM
Quick Reply: injector scaling help
