please help with ecuflash problem!
Old Sep 25, 2008 | 12:25 AM
magyar86's Avatar
hey guys please help me out.
im sure its something very easy that im missing but i cant ecuflash to get my rom off my car.
i think its just a path issue but idk...ive been messing with this computer for 2 days straight trying to get everything back running after it crashed.
but here is what im getting when i try to get my rom off my car
any help will be GREATLY appreciated!! thanks
Old Sep 25, 2008 | 12:31 AM
magyar86's Avatar
i forgot to mention ive tried to uninstall and reinstall ecuflash a million times but it keeps doing the same thing and i am not that computer savy so i might not be deleting everything that has to do with ecuflash off my computer or something like that. and sorry if this has been covered
like i said i think it has to do with "rom file directory" "color map directory" and "metadata directory" paths. if anyone can give me the paths so i can make sure there right that would really help. thanks guys!!
Old Sep 25, 2008 | 07:05 AM
magyar86's Avatar
morning bump....
Old Sep 25, 2008 | 10:20 AM
G20's Avatar
G20
usually, be default the rom metadata files are in c:\program files\openecu\ecuflash\rommetadata . If they're not there then must be in your user's profile application data directory. Open windows explorer and search for one of the files like '94170008.xml'. This will let you the file path.
Old Sep 25, 2008 | 10:38 AM
magyar86's Avatar
yea it was the metadata path. but can someone look real quick and tell me what the path is for rom file directory? my doesnt have a path right now and im not sure what it should be. thanks g20!
Old Sep 25, 2008 | 03:25 PM
G20's Avatar
G20
try this: Start EcuFlash, select File\Options menu, select Directories\Metadata Directory from the popup dialog, enter rommetadata into the textbox on the right panel and close the dialog.
If it failed, please click on the ... button next to the textbox to see which directory that it's currently default to and let me know.
Old Sep 25, 2008 | 03:50 PM
magyar86's Avatar
i have the rommetadata path correct now, i was able to get into my ecu. the only thing that is messed up now is the first one "rom file directory" it has no path, i dont know what that one is for but im sure it does something. so if you could please tell me the path for "rom file directory" and i should be set, thanks again man!!
Old Sep 25, 2008 | 05:59 PM
G20's Avatar
G20
the rom file directory is the one that you'll save your modified maps to. Usually the default is the "MyData" directory in EcuFlash main directory but you can change it to any directory you want.
Old Sep 25, 2008 | 06:13 PM
magyar86's Avatar
ahhh!! ok i see that once i got my rom off my ecu it filled in the path...geez i feel like a loser, but anyway thanks for the help!!
magyar86
Mar 26, 2016 03:36 AM
magyar86
Oct 11, 2015 10:34 AM
magyar86
Sep 20, 2015 06:26 PM
magyar86
11
Dec 30, 2010 09:48 PM
magyar86
Jul 20, 2009 11:34 PM
Quick Reply: please help with ecuflash problem!
