evoscan 2.5 Log and reading ACD
Any issue with this?
I can't log the wheel speed sensors all the values flicker..
When retrieving codes it always come up with something new.. But always has front right wheel speed sensor open?? Is that abnormal?
I’ve also gotten:
G senor errors
Brake switch
Pump failure.
I’ve also gotten:
G senor errors
Brake switch
Pump failure.
EvoM Community Team
I believe the evoscan 1.3 cables with the capability to properly log ACD/ABS ecus and use some of the actuators were released sometime around February/March.
I'm not 100% sure, but if there is a large piece of electronic equipment between the obdII and alternate connector it may be the newer one. Not 100% sure on that though
Thread about the cables is here - I am also on the same boat - older cable - not able to get AYC/ABS logging properly
https://www.evolutionm.net/forums/sh...d.php?t=359064
LOL .. Thanks I figure that out.. But The light never flashed.. They only flash when I moved pin 1 to 15 on the car side and when I plug in the logging cable the ACD and ABS light then Flash. But I can't even pull a log or Error code..
I guess the question was around flashing light are also a different error code??
211Ratsbud
Apr 1, 2014 09:05 PM
darkmitsu
Lancer Engine Management / Tuning Forums
May 19, 2010 08:37 PM
Waz996
Dec 5, 2006 08:30 AM
