Evoscan help
Evoscan help
So I got my Tractrix cable in today and wanted to see if everything is working, so I hooked it up but I get a dialog box saying " USB cable device not responding". But when I use ECUFlash to download my ecu it worked fine. Anybody have any ideas? I uninstalled the usb driver and reinstalled onto Evoscan, USB drivers, x84, and still nothing.
When it asks you to install for the first time I just did the normal install, then I heard that you had to install it directly to EVoscan, so I un-installed it, re-installed directly to evoscan and it still won't work. I was looking up fixes and ran across this guy on youtube starting up evoscan, I did everything the same except after he installs the USB driver x86, another dialog box pops up for the serial port, I never got that pop up box.
http://www.youtube.com/watch?v=BmoNoXd0ltc
1 Post
What is that for? What does Baudrate mean??
The usual connection speed for most (computer related) devices is 9600 BAUD, Port [insert COM port # here], data bits set to 8, Parity: None, Stop Bits 1, and no flow control.
I remember when I fired up Evoscan I had a similar problem, in where I could not connect either.
Can you post a screenshot of the problem? Or explain the steps you are taking to connect Evoscan to your car? I'm sure your just missing an easy step.
-Bink
All BAUD means is how much information is sent per second.
-Bink
-Bink
