Ralliart no pasa de 15 psi........ help
Ralliart does not happen from 15 psi........ help
Hello:
I did a Flash to the ecu with the map of ralliart EDM, in 2 mitsubishi lancer evo the VIII, in one of them the pressure was of 21 psi stablly and in my car the pressure does not happen from 18 psi and lowers up to 15 psi. Has same pressure with the stock map that with the map ralliart. ¿That can be? , Solenoid? escape at pipes?.
[img=http://img402.imageshack.us/img402/7897/boostralliartqg5.th.jpg][img=http://img402.imageshack.us/images/thpix.gif]
[img=http://img362.imageshack.us/img362/7559/fuelim2.th.jpg][img=http://img362.imageshack.us/images/thpix.gif]
[img=http://img362.imageshack.us/img362/469/ignitionuu4.th.jpg][img=http://img362.imageshack.us/images/thpix.gif]
Regards.
Regards.
Hello:
If the photos are of my mod ralliart. I do not have knowledge of because the blocks have zero value. The achivo I obtained it in a e-mail. But the same file in another evo was working to 22 psi.
Regards.
Regards.
Did you copy the maps or the whole ROM? What BCS are you using?
Copiastes el mapa de otro ROM o flasheastes el mapa de otro carro? Cual solenoide de turbo tienes instalado el original? Si solo cargas 15 libras entonces parece que estas corriendo a la presion del wastegate? Si quieres me envias un private message porque no se si permiten español en este foro.
Red_Evolution
13
Nov 12, 2008 08:14 AM
Poloiceberg
Oct 27, 2008 08:43 PM
