Ecuflash v1.39 thread
Old Oct 10, 2008, 06:24 PM
Jorge T's Avatar
new version available...checking it out now
Old Oct 10, 2008, 06:33 PM
nothere's Avatar
from perusing the subie forum, the new ecuflash is a fix for the new flash unit on new subies.
AmF_15's Avatar
sweetness! thanks
Old Oct 11, 2008, 01:44 AM
hfalex's Avatar
thanks
Old Oct 11, 2008, 07:57 AM
Jorge T's Avatar
there is an installation bug: it installed x64 tactrix drivers in my 32 bit xppro laptop, so nothing worked. I worked around it by deleteing all old (if not you'll end up with 5 driver instead of 3) tactrix drivers and using the specific location option to x86 dir during the found new hardware routine.
Old Oct 13, 2008, 07:27 AM
dan l's Avatar
For those of you with the unsupported serial # Taxtrix cables don't bother installing 1.39. Once again it will peg the processor on a read or write as they STILL haven't fixed the issue. Which proves the point that I made the other day, don't upgrade your working system until you have a valid reason to do so. Stick with 1.38 and the cable hack or the tried and true 1.29.
Old Oct 13, 2008, 08:51 AM
fknlowpsi's Avatar
yea i tried 1.39 no luck kept getting not responding/ so i downloaded 1.29a. works like a charm.
Old Oct 13, 2008, 02:46 PM
Mattjin's Avatar
Yeap, same old issue for me since v1.35... crash on ROM read.
Old Oct 13, 2008, 04:08 PM
nothere's Avatar
1.39 is intended for OP2 mostly, if you are still flashing with 1.3 why bother. It is very likely there will be another version before we are able to do any logging with op2. So keep your powder dry.
Old Oct 13, 2008, 04:14 PM
Kracka's Avatar
I installed it last night and am using it with no issues at all. It has a lot of new tables visible that weren't before. I try to stay current so I download the updates as they are released.
Compaq laptop
Windows Vista
AMD Turion 64
Old Oct 13, 2008, 05:16 PM
Smoothgangsta's Avatar
Hopefully the hack will be released soon to resolve the issue with the unsupported serial #'s. Has anyone emailed the guys working on 1.39 about the x64 drivers being installed instead of the x86 32-bit drivers? I for one would like to upgrade over 1.38 since it says the following:
"skip writing 0xFF blocks for increased flashing speed "
I would like to see what the speed improvements would be like vs. 1.38.
Old Oct 13, 2008, 06:06 PM
Kracka's Avatar
I did notice it being quicker.
Old Oct 13, 2008, 06:59 PM
Jorge T's Avatar
I did see it being quicker too, so far so good, no crashes on read or veiwing graphs. Works with LW3 openport 1.3 too.
Old Oct 13, 2008, 07:08 PM
nothere's Avatar
Jorge T,
are you flashing with the op2?
Old Oct 13, 2008, 07:15 PM
Has anyone email'ed or know the email address to the developers writing the code for Ecuflash 1.39? I would like to email them to see if they know about 1.39 only installing the 64-bit drivers and not the x86 32-bit.
Quick Reply: Ecuflash v1.39 thread
