Volumetric efficiency
Location: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
It seems to me that the MUT_31 logs volumetric efficiency
<DataListItem DataLog="Y" Color="#fa903a" Display="Volumetric Efficiency" LogReference="VE" RequestID="31"
Eval="x/255*100" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="130" ChartMin="0"
ChartMax="130" ScalingFactor="0.01" Notes="Volumetric efficiency is the ratio, how close the actual volumetric flow rate is to the theoretical volumetric flow rate. " Priority="1"
Visible="False" />
Anyone to confirm it on different ROM models?
Visible="False" />
My MAP controlled engine has 3 VE tables. But I could not find them in MAF controlled ROMs.
Therefore I assume it is calculated from MAF compensation tables.
This variable will be build by a 2D table lookup.
The left row is the same MAF Hz lookup Table that is used by the maf scaling table
The right row is this table. Bez has already called this MAF_Smooth* so I adopt this name. I dont know if this is vol. eff.
This value will be used as a factor in the maf function and build some kind of MAF Airflow value.
Code:
ROM:00005576 MAF_Hz_Tab_row: .data.l RPM_Tab_Find ; DATA XREF: ROM:off_13B10 ROM:0000557A .data.l MAF_Hz_Word ROM:0000557E .data.w h'15 ROM:00005580 .data.w h'C0 ROM:00005582 .data.w h'100 ROM:00005584 .data.w h'200 ROM:00005586 .data.w h'300 ROM:00005588 .data.w h'400 ROM:0000558A .data.w h'500 ROM:0000558C .data.w h'600 ROM:0000558E .data.w h'700 ROM:00005590 .data.w h'800 ROM:00005592 .data.w h'900 ROM:00005594 .data.w h'A00 ROM:00005596 .data.w h'B00 ROM:00005598 .data.w h'C00 ROM:0000559A .data.w h'1000 ROM:0000559C .data.w h'1400 ROM:0000559E .data.w h'1800 ROM:000055A0 .data.w h'2000 ROM:000055A2 .data.w h'2800 ROM:000055A4 .data.w h'3000 ROM:000055A6 .data.w h'3800 ROM:000055A8 .data.w h'4000
Code:
ROM:0000351C MAF_Smooth_Tab: .data.b 2 ; DATA XREF: ROM:off_13B28 ROM:0000351D .data.b 0 ROM:0000351E .data.l RPM_Tab_Find ROM:00003522 .data.b h'80 ; Ç ROM:00003523 .data.b h'80 ; Ç ROM:00003524 .data.b h'85 ; à ROM:00003525 .data.b h'86 ; å ROM:00003526 .data.b h'85 ; à ROM:00003527 .data.b h'84 ; ä ROM:00003528 .data.b h'86 ; å ROM:00003529 .data.b h'86 ; å ROM:0000352A .data.b h'86 ; å ROM:0000352B .data.b h'87 ; ç ROM:0000352C .data.b h'87 ; ç ROM:0000352D .data.b h'87 ; ç ROM:0000352E .data.b h'87 ; ç ROM:0000352F .data.b h'89 ; ë ROM:00003530 .data.b h'87 ; ç ROM:00003531 .data.b h'87 ; ç ROM:00003532 .data.b h'85 ; à ROM:00003533 .data.b h'85 ; à ROM:00003534 .data.b h'85 ; à ROM:00003535 .data.b h'85 ; à ROM:00003536 .data.b h'85 ; à
Code:
ROM:00013A6E mov.l @(h'E0,pc), r10 ; [00013B50] = BaroTemp_Comp_Value ROM:00013A70 mov.w @r10, r10 ROM:00013A72 extu.w r10, r10 ROM:00013A74 mov.l @(h'B8,pc), r11 ; [00013B30] = MAF_Smooth_Var ROM:00013A76 mov.w @r11, r11 ROM:00013A78 extu.w r11, r11 ROM:00013A7A mulu r10, r11 ROM:00013A7C sts macl, r12 ROM:00013A7E mov.l @(h'A4,pc), r4 ; [00013B24] = MAF_Airflow ROM:00013A80 mov.w @r4, r4 ROM:00013A82 extu.w r4, r4 ; r4= MAF_Airflow ROM:00013A84 mov r12, r5 ; r5=r12= MAF_Smooth * BaroTemp_Comp ROM:00013A86 mov.w @(h'3A,pc), r6 ; [00013AC4] = h'4000 ROM:00013A88 mov.l @(h'C8,pc), r10 ; [00013B54] = r4_mul_r5_div_r6_round ROM:00013A8A jsr @r10 ; r4_mul_r5_div_r6_round ROM:00013A8C nop ROM:00013A8E mov.l @(h'C8,pc), r11 ; [00013B58] = MAF_Airflow_corr_1 ROM:00013A90 mov.w r0, @r11
Thanx JoeBee,
I have seen this piece of code in MAF controlled ROMs. The only thing is that I do not have these MAF scalings in my MAP controlled engine, and still have the variable which can be logged via MUT_31 on similar place -> IPW calculation. The only meaning that I can give to what I see in my ROM is Volumetric efficiency, I have logged MUT_31 recently and it takes the values directly from those 3D tables, modifying of these tables has direct effect on IPW. You may call it AirFlow scaling/smoothing in MAF controlled ROM, but there is no measured airflow to scale in MAP controlled one. Barometric reading is scaled at different place.
I guess the only way to find out if my assumption is correct is to calculate consumption via VE and compare it with IPW consumption calculation. All necessary variables are already available via MUT
MAF Sensor:
MPG = (14.7 * 6.17 * 454 * VSS * 0.621371) / (3600 * MAF / 100)
= 710.7 * VSS / MAF
14.7 - grams of air to 1 gram of gasoline - ideal air/fuel ratio
6.17 - pounds per gallon - density of gasoline
4.54 - grams per pound - conversion
VSS - vehicle speed in kilometers per hour
0.621371 - miles per hour/kilometers per hour - conversion
3600 - seconds per hour - conversion
MAF - mass air flow rate in 100 grams per second
100 - to correct MAF to give grams per second
No MAF (Uses MAP and Absolute Temp to approximate MAF):
IMAP = RPM * MAP / IAT
MAF = (IMAP/120)*(VE/100)*(ED)*(MM)/(R)
MAP - Manifold Absolute Pressure in kPa
IAT - Intake Air Temperature in Kelvin
R - Specific Gas Constant (8.314 JM/K)
MM - Average molecular mass of air (28.97 g/M)
VE - volumetric efficiency measured in percent
ED - Engine Displacement in liters
source:
http://www.mp3car.com/vbulletin/engi...-maf-obd2.html
= 710.7 * VSS / MAF
source:
For the Evo, MUT_31 is just a table lookup like what JoeBee said. It is what I call MAF compensation (and Bez calls MAF smooth) and is used for calculating the corrected airflow rate per Hz.
correctedairflowrateperHz = (airflowperHzlookup + 0x8C)*(MAF_compensation*air_density_correction)/0x4000
Booztd3
Mar 27, 2015 06:49 AM
Brian Ten Pow
Dec 2, 2009 12:04 AM
7107, absolute, altitude, ecuflash, efficiency, find, gram, h87, imap120ve100edmmr, lancer, maf, manifold, mpg, pressure, volumetric
